AutoCAD Forum
Can use Object Snap, there is an error saying "Unknow command" for each option.
3 REPLIES 3
642 Views, 3 Replies
Welcome,
I'm new to AutoCAD so please pardon my knowledge about this enviroment. I'm using AutoCAD 2015 student version which I've installed a few days back. I was following some online tutorial without any problems until now when I was supposed to shift + right click into options like endpoint, midpoint snapping - whenever I do so I see info above command line saying for example "Command: _endp Unknown command "ENDP".  Press F1 for help." I have snapping and snapping tracking turned on in setting of course. Any idea why am I experiencing this issue or how can I fix it? I would be really grateful for any help. Smiley Wink
3 REPLIES 3
pendean
You have to have a command active in order for you to be able to set osnaps with that method.
Start a command first... .
nestly2
Welcome to the Autodesk Forums.
OSnaps only work when AutoCAD expects the user to specify a point. (point acquistion mode)  To test, start the Line command first, then Shift-Right-Click.
in reply to: nestly2
Thank you very much. It required just that indeed. I wish there was info in the program saying something similar to "Specify command - like line" instead of "Unknown command" that would save time for some noobs like me. Thanks again.
”Boost
