AutoCAD Forum
Can the template a drawing is based on be identified?
2 REPLIES 2
StoneEdgeFarm
402 Views, 2 Replies
Is there any way to identify the template (?.dwt) an Autocad drawing is based on?
Thanks for any suggestions, I can't find anything on this subject.
Best regards,
Mike
Tags (1)
2 REPLIES 2
pendean
in reply to: StoneEdgeFarm
Only if you placed a marker/note in the template file in the first place for just queries: we do it and perhaps you should start doing it too if you haven't done so already.
StoneEdgeFarm
in reply to: pendean
Thank you Dean, you are ever so wise. I will consider this a solution.
Very best,
Mike Bartlett
”Boost
