I am having trouble remembering a command. I am trying to dimension a 3D model in autocad 2015. Whenever I try to add in a dimension it is automatically attached to the default plane. I used to use a specific command and then type in "view" and then I would be able to put the dimensions in. Does anyone have any idea what the command would be for that?
Solved by jggerth1. Go to Solution.
UCS View will set the active UCS to the current view, is that what you mean?
