Hello there.
I changed the F1 key command to open "cancel" but it still opens "HELP"! I attached a picture and as you can see, it says that the key for CANCEL is F1 - I did this configuration 1000 times already (though on AutoCad with NETWORK license) and it every time worked but not today after a fresh install of Autocad Architecture 2015 (Standalone License)!
I hope you can help me, wasted already 2 hours using google, my boss is not happy at all 😕
Solved by nestly2. Go to Solution.
because most users never need the autocad HELP function, but most users definitely accidentally hit the F1 key trying to hit escape, thus launching HELP which is a time waster. DUH!
I'm having no luck reassigning the F1 key in 2016, though it was a simple task in 2012 version. Why on earth indeed.
BY THE WAY - If F1 opens the help pane and halts your production, try this because it worked for me. F1 help pain is a WINDOWSfunction that can be disabled by deleting the help pain file helppane.exe - This should allow you to program the F1 key for anything in AutoCAD that you choose without having the help pane pop up any longer. The drawback is occasionally when there's an update, the help pain is reinstalled and you have to go through the process again, which isn't very difficult. As long as you don't need Windows help this is a perfect solution. Whenever I need help in Windows I just go to Google or YouTube Which is far more efficient.
