AutoCAD Forum
Can't interact with a piece created.
3 REPLIES 3
Skiian360
379 Views, 3 Replies
Hello Everyone,
I'm working on a design for a weight cuff in my class on the AUTOCAD program in my high school, I created the main portion of it and now cannot interact with it to export it as a .stl file in order to print for our first test. If Anyone could please help me out in any way I will be very appreciative.
Thank you very much for your time in advance,
Ian
3 REPLIES 3
Patchy
in reply to: Skiian360
Delete the lines and insert the block that is in your drawing.
This is what I get after STLOUT and opened with another program.
(Change .txt to .stl in the file attached)
Skiian360
in reply to: Patchy
Thank you for your help, but it still does not work the way it should 😕 I should have specified previously that I can export as a .stl file but it's still not registered by the makerbot software. Thanks anyways!
JDMather
You  need to Explode the block before you can save as stl file.
Run the List command on the part before saving as stl.  Does it say Solid?
Zip and attach your stl file here.
Right click on the file name and select Send to Compressed (zipped) Folder.
Attach the resulting *.zip file here.
”Boost
