AutoCAD Forum
Can't install - communication error
1 REPLY 1
KevinDFZ
221 Views, 1 Reply
I get the "communication error" when I try to install AutoCAD 2015 using the installer. So I tried to find the "download now" option, but there isn't one? Neither is a "browser download" option. The only option available in the software download page is "install now". So how do I install this...?
1 REPLY 1
pendean
in reply to: KevinDFZ
If you are just looking for a product download you should be able to find it at the Autodesk Customer Service Virtual Agent:
•In the preferences or options area of your preferred browser, remove pop-up blockers and allow access to all *autodesk.com sites.
•In the preferences or options area of your preferred browser, delete cookies, temporary internet files, and history.
1. Turn off your personal firewall or VPN, if you use one.
2. Disable UAC
3. Close and reopen your preferred browser.
4. Go to http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
5. Select the choice "Download Links".
6. Select your product, then variant, then version as applicable.
7. You should now be presented with the choice to download your software.
”Boost
