If anyone can help that would be great.
I've been running Autocad Lt 2008 - but recently I began having problems due to the latest updates from window.
I was no longer able to edit lines and zoom in.
I tried getting a patch - but that did nothing because 2008 is no longer supported.
Next step is/was to up-grade to 2015 - I download the trial version - I really need to get up and running due to major deadlines.
The product did download - but I am unable to get it installed. AutoCad LT 2015 FAILED "An error occurred while installing this product."
I've tried everything - from downloading from virtual assistant. Turned off all virus and firewalls. Did the windows clean-up thing they suggested. And also The AutoDesk Binding Hot Fix Utility which said already up dated - There is no need to install this fix.
I also tired to find a "Live Chat" but could not.
Every time I did a search for my problems all the same topics came up and none where able to help.
If anyone can help that would be great - or if anyone knows where Live Chat is please direct me. I have been dealing with this issue for the 29 hours and have not been able to get anywhere.
Oh and the best part is that when I try and open AutoCad LT 2008 - it is now asking for a product key code.
HELP!
Thank you.
Heres the error log:
2014/9/25:16:07:25 Mario MARIO-OPTIPLEX === Setup started on MARIO-OPTIPLEX by Mario ===
2014/9/25:16:07:25 Mario MARIO-OPTIPLEX Path_Length: 152
2014/9/25:16:07:25 Mario MARIO-OPTIPLEX Current Directory C:\Autodesk\AutoCADLT_2015_SWL_English_Win_32_64bit_R1_wi_en-us
2014/9/25:16:07:25 Mario MARIO-OPTIPLEX Launch
2014/9/25:16:07:25 Mario MARIO-OPTIPLEX CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/ACDLT/WI/AutoCADLT_2015_SWL_English_Win_32_64bit_R1_wi_en-... /akamai /trialMode /skipEULA /auth authparam /sid Trial1411686380111
2014/9/25:16:07:25 Mario MARIO-OPTIPLEX Current Directory C:\Users\Mario\AppData\Local\Temp\_AI7001.tmp
2014/9/25:16:08:19 Mario MARIO-OPTIPLEX === Setup ended ===
2014/9/25:16:08:09 Mario MARIO-OPTIPLEX Error downloading. Please Install Now again from the Autodesk website. 2014/9/25:16:08:19 Mario MARIO-OPTIPLEX === Setup ended ===
2014/9/25:16:09:44 Mario MARIO-OPTIPLEX === Setup started on MARIO-OPTIPLEX by Mario ===
2014/9/25:16:09:44 Mario MARIO-OPTIPLEX Path_Length: 152
2014/9/25:16:09:44 Mario MARIO-OPTIPLEX Current Directory C:\Autodesk\AutoCADLT_2015_SWL_English_Win_32_64bit_R1_wi_en-us
2014/9/25:16:09:44 Mario MARIO-OPTIPLEX Launch
2014/9/25:16:09:44 Mario MARIO-OPTIPLEX CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/ACDLT/WI/AutoCADLT_2015_SWL_English_Win_32_64bit_R1_wi_en-... /akamai /trialMode /skipEULA /auth authparam /sid Trial1411686560244
2014/9/25:16:09:44 Mario MARIO-OPTIPLEX Current Directory C:\Users\Mario\AppData\Local\Temp\_AI8E79.tmp
2014/9/25:16:10:17 Mario MARIO-OPTIPLEX === Setup ended ===
2014/9/25:16:10:14 Mario MARIO-OPTIPLEX Error downloading. Please Install Now again from the Autodesk website. 2014/9/25:16:10:18 Mario MARIO-OPTIPLEX === Setup ended ===
2014/9/25:16:11:45 Mario MARIO-OPTIPLEX === Setup started on MARIO-OPTIPLEX by Mario ===
2014/9/25:16:11:45 Mario MARIO-OPTIPLEX Path_Length: 152
2014/9/25:16:11:45 Mario MARIO-OPTIPLEX Current Directory C:\Autodesk\AutoCADLT_2015_SWL_English_Win_32_64bit_R1_wi_en-us
2014/9/25:16:11:45 Mario MARIO-OPTIPLEX Launch
2014/9/25:16:11:45 Mario MARIO-OPTIPLEX CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/ACDLT/WI/AutoCADLT_2015_SWL_English_Win_32_64bit_R1_wi_en-... /akamai /trialMode /skipEULA /auth authparam /sid Trial1411686685576
2014/9/25:16:11:45 Mario MARIO-OPTIPLEX Current Directory C:\Users\Mario\AppData\Local\Temp\_AI66BE.tmp
2014/9/25:16:12:25 Mario MARIO-OPTIPLEX === Setup ended ===
2014/9/25:16:11:47 Mario MARIO-OPTIPLEX === Setup started on MARIO-OPTIPLEX by Mario ===
2014/9/25:16:11:47 Mario MARIO-OPTIPLEX Path_Length: 152
2014/9/25:16:11:47 Mario MARIO-OPTIPLEX Current Directory C:\Users\Mario\AppData\Local\Temp\_AI66BE.tmp
2014/9/25:16:11:47 Mario MARIO-OPTIPLEX Launch
2014/9/25:16:12:23 Mario MARIO-OPTIPLEX Error downloading. Please Install Now again from the Autodesk website. 2014/9/25:16:12:26 Mario MARIO-OPTIPLEX === Setup ended ===
2014/9/25:16:26:50 Mario MARIO-OPTIPLEX === Setup started on MARIO-OPTIPLEX by Mario ===
2014/9/25:16:26:50 Mario MARIO-OPTIPLEX Path_Length: 152
2014/9/25:16:26:50 Mario MARIO-OPTIPLEX Current Directory C:\Autodesk\AutoCADLT_2015_SWL_English_Win_32_64bit_R1_wi_en-us
2014/9/25:16:26:50 Mario MARIO-OPTIPLEX Launch
2014/9/25:16:26:50 Mario MARIO-OPTIPLEX CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/ACDLT/WI/AutoCADLT_2015_SWL_English_Win_32_64bit_R1_wi_en-... /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/25:16:26:50 Mario MARIO-OPTIPLEX Current Directory C:\Users\Mario\AppData\Local\Temp\_AI363D.tmp
2014/9/25:16:27:15 Mario MARIO-OPTIPLEX === Setup ended ===
2014/9/25:16:27:11 Mario MARIO-OPTIPLEX Error downloading. Please Install Now again from the Autodesk website. 2014/9/25:16:27:16 Mario MARIO-OPTIPLEX === Setup ended ===
2014/9/25:16:28:19 Mario MARIO-OPTIPLEX === Setup started on MARIO-OPTIPLEX by Mario ===
2014/9/25:16:28:19 Mario MARIO-OPTIPLEX Path_Length: 152
2014/9/25:16:28:19 Mario MARIO-OPTIPLEX Current Directory C:\Autodesk\AutoCADLT_2015_SWL_English_Win_32_64bit_R1_wi_en-us
2014/9/25:16:28:19 Mario MARIO-OPTIPLEX Launch
2014/9/25:16:28:19 Mario MARIO-OPTIPLEX CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/ACDLT/WI/AutoCADLT_2015_SWL_English_Win_32_64bit_R1_wi_en-... /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/25:16:28:19 Mario MARIO-OPTIPLEX Current Directory C:\Users\Mario\AppData\Local\Temp\_AI87A7.tmp
2014/9/25:16:29:23 Mario MARIO-OPTIPLEX === Setup ended ===
2014/9/25:16:28:21 Mario MARIO-OPTIPLEX === Setup started on MARIO-OPTIPLEX by Mario ===
2014/9/25:16:28:21 Mario MARIO-OPTIPLEX Path_Length: 152
2014/9/25:16:28:21 Mario MARIO-OPTIPLEX Current Directory C:\Users\Mario\AppData\Local\Temp\_AI87A7.tmp
2014/9/25:16:28:21 Mario MARIO-OPTIPLEX Launch
2014/9/25:16:29:16 Mario MARIO-OPTIPLEX Error downloading. Please Install Now again from the Autodesk website. 2014/9/25:16:29:24 Mario MARIO-OPTIPLEX === Setup ended ===
2014/9/26:07:25:04 Mario MARIO-OPTIPLEX === Setup started on MARIO-OPTIPLEX by Mario ===
2014/9/26:07:25:04 Mario MARIO-OPTIPLEX Path_Length: 152
2014/9/26:07:25:04 Mario MARIO-OPTIPLEX Current Directory C:\Autodesk\AutoCADLT_2015_SWL_English_Win_32_64bit_R1_wi_en-us
2014/9/26:07:25:04 Mario MARIO-OPTIPLEX Launch
2014/9/26:07:25:04 Mario MARIO-OPTIPLEX CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/ACDLT/WI/AutoCADLT_2015_SWL_English_Win_32_64bit_R1_wi_en-... /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/26:07:25:04 Mario MARIO-OPTIPLEX Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2014/9/26:07:28:32 Mario MARIO-OPTIPLEX Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2014/9/26:07:28:34 Mario MARIO-OPTIPLEX Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2014/9/26:07:28:35 Mario MARIO-OPTIPLEX === Setup ended ===
2014/9/26:07:32:17 Mario MARIO-OPTIPLEX === Setup started on MARIO-OPTIPLEX by Mario ===
2014/9/26:07:32:17 Mario MARIO-OPTIPLEX Path_Length: 152
2014/9/26:07:32:17 Mario MARIO-OPTIPLEX Current Directory C:\Autodesk\AutoCADLT_2015_SWL_English_Win_32_64bit_R1_wi_en-us
2014/9/26:07:32:17 Mario MARIO-OPTIPLEX Launch
2014/9/26:07:32:17 Mario MARIO-OPTIPLEX CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/ACDLT/WI/AutoCADLT_2015_SWL_English_Win_32_64bit_R1_wi_en-... /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/26:07:32:17 Mario MARIO-OPTIPLEX Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2014/9/26:07:32:22 Mario MARIO-OPTIPLEX === Setup ended ===
2014/9/26:08:28:14 Mario MARIO-OPTIPLEX === Setup started on MARIO-OPTIPLEX by Mario ===
2014/9/26:08:28:14 Mario MARIO-OPTIPLEX Path_Length: 152
2014/9/26:08:28:14 Mario MARIO-OPTIPLEX Current Directory C:\Autodesk\AutoCADLT_2015_SWL_English_Win_32_64bit_R1_wi_en-us
2014/9/26:08:28:14 Mario MARIO-OPTIPLEX Launch
2014/9/26:08:28:14 Mario MARIO-OPTIPLEX CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/ACDLT/WI/AutoCADLT_2015_SWL_English_Win_32_64bit_R1_wi_en-... /akamai /trialMode /skipEULA /auth authparam /sid Trial1411745269501
2014/9/26:08:28:14 Mario MARIO-OPTIPLEX Current Directory C:\Users\Mario\AppData\Local\Temp\_AI6569.tmp
2014/9/26:08:28:47 Mario MARIO-OPTIPLEX === Setup ended ===
2014/9/26:08:28:16 Mario MARIO-OPTIPLEX === Setup started on MARIO-OPTIPLEX by Mario ===
2014/9/26:08:28:16 Mario MARIO-OPTIPLEX Path_Length: 152
2014/9/26:08:28:16 Mario MARIO-OPTIPLEX Current Directory C:\Users\Mario\AppData\Local\Temp\_AI6569.tmp
2014/9/26:08:28:16 Mario MARIO-OPTIPLEX Launch
2014/9/26:08:28:43 Mario MARIO-OPTIPLEX Error downloading. Please Install Now again from the Autodesk website. 2014/9/26:08:28:48 Mario MARIO-OPTIPLEX === Setup ended ===
2014/9/26:08:29:44 Mario MARIO-OPTIPLEX === Setup started on MARIO-OPTIPLEX by Mario ===
2014/9/26:08:29:44 Mario MARIO-OPTIPLEX Path_Length: 152
2014/9/26:08:29:44 Mario MARIO-OPTIPLEX Current Directory C:\Autodesk\AutoCADLT_2015_SWL_English_Win_32_64bit_R1_wi_en-us
2014/9/26:08:29:44 Mario MARIO-OPTIPLEX Launch
2014/9/26:08:29:44 Mario MARIO-OPTIPLEX CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/ACDLT/WI/AutoCADLT_2015_SWL_English_Win_32_64bit_R1_wi_en-... /akamai /trialMode /skipEULA /auth authparam /sid Trial1411745331630
2014/9/26:08:29:44 Mario MARIO-OPTIPLEX Current Directory C:\Users\Mario\AppData\Local\Temp\_AIC64D.tmp
2014/9/26:08:33:34 Mario MARIO-OPTIPLEX === Setup ended ===
2014/9/26:08:29:51 Mario MARIO-OPTIPLEX === Setup started on MARIO-OPTIPLEX by Mario ===
2014/9/26:08:29:51 Mario MARIO-OPTIPLEX Path_Length: 152
2014/9/26:08:29:51 Mario MARIO-OPTIPLEX Current Directory C:\Users\Mario\AppData\Local\Temp\_AIC64D.tmp
2014/9/26:08:29:51 Mario MARIO-OPTIPLEX Launch
2014/9/26:08:33:32 Mario MARIO-OPTIPLEX Error downloading. Please Install Now again from the Autodesk website. 2014/9/26:08:33:35 Mario MARIO-OPTIPLEX === Setup ended ===
2014/9/26:08:57:23 Mario MARIO-OPTIPLEX === Setup started on MARIO-OPTIPLEX by Mario ===
2014/9/26:08:57:23 Mario MARIO-OPTIPLEX Path_Length: 152
2014/9/26:08:57:23 Mario MARIO-OPTIPLEX Current Directory C:\Autodesk\AutoCADLT_2015_SWL_English_Win_64bit_dlm
2014/9/26:08:57:23 Mario MARIO-OPTIPLEX Launch
2014/9/26:08:57:23 Mario MARIO-OPTIPLEX CommandLine
2014/9/26:08:57:23 Mario MARIO-OPTIPLEX Current Directory C:\Users\Mario\AppData\Local\Temp\_AI16CE.tmp
2014/9/26:08:57:30 Mario MARIO-OPTIPLEX === Setup ended ===
2014/9/26:08:57:24 Mario MARIO-OPTIPLEX Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Mario\AppData\Local\Temp\_AI16CE.tmp\Setup\AcSetup.dll
2014/9/26:08:57:24 Mario MARIO-OPTIPLEX Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/9/26:08:57:30 Mario MARIO-OPTIPLEX PageOpen LaunchDialog
2014/9/26:08:57:36 Mario MARIO-OPTIPLEX PageOpen LicenseDialog
2014/9/26:08:57:41 Mario MARIO-OPTIPLEX PageOpen ProductInfoDialog
2014/9/26:08:57:52 Mario MARIO-OPTIPLEX PageOpen ProductSelectionDialog2
2014/9/26:08:58:12 Mario MARIO-OPTIPLEX PageOpen FullProgressDialog
2014/9/26:08:58:12 Mario MARIO-OPTIPLEX Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\AutoCADLT_2015_SWL_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2014/9/26:08:58:14 Mario MARIO-OPTIPLEX Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2014/9/26:08:58:15 Mario MARIO-OPTIPLEX PageOpen InstallCompleteDialog
2014/9/26:08:58:30 Mario MARIO-OPTIPLEX === Setup ended ===
2014/9/26:09:52:35 Mario MARIO-OPTIPLEX === Setup started on MARIO-OPTIPLEX by Mario ===
2014/9/26:09:52:35 Mario MARIO-OPTIPLEX Path_Length: 152
2014/9/26:09:52:35 Mario MARIO-OPTIPLEX Current Directory C:\Autodesk\AutoCADLT_2015_SWL_English_Win_64bit_dlm
2014/9/26:09:52:35 Mario MARIO-OPTIPLEX Launch
2014/9/26:09:52:35 Mario MARIO-OPTIPLEX CommandLine
2014/9/26:09:52:35 Mario MARIO-OPTIPLEX Current Directory C:\Users\Mario\AppData\Local\Temp\_AIA27A.tmp
2014/9/26:09:52:53 Mario MARIO-OPTIPLEX === Setup ended ===
2014/9/26:09:52:38 Mario MARIO-OPTIPLEX === Setup started on MARIO-OPTIPLEX by Mario ===
2014/9/26:09:52:38 Mario MARIO-OPTIPLEX Path_Length: 152
2014/9/26:09:52:38 Mario MARIO-OPTIPLEX Current Directory C:\Users\Mario\AppData\Local\Temp\_AIA27A.tmp
2014/9/26:09:52:38 Mario MARIO-OPTIPLEX Launch
2014/9/26:09:52:39 Mario MARIO-OPTIPLEX Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Mario\AppData\Local\Temp\_AIA27A.tmp\Setup\AcSetup.dll
2014/9/26:09:52:39 Mario MARIO-OPTIPLEX Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/9/26:09:52:52 Mario MARIO-OPTIPLEX PageOpen LaunchDialog
2014/9/26:09:52:58 Mario MARIO-OPTIPLEX PageOpen LicenseDialog
2014/9/26:09:53:02 Mario MARIO-OPTIPLEX PageOpen ProductInfoDialog
2014/9/26:09:53:12 Mario MARIO-OPTIPLEX PageOpen ProductSelectionDialog2
2014/9/26:09:53:27 Mario MARIO-OPTIPLEX PageOpen FullProgressDialog
2014/9/26:09:53:28 Mario MARIO-OPTIPLEX Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\AutoCADLT_2015_SWL_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2014/9/26:09:53:30 Mario MARIO-OPTIPLEX Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2014/9/26:09:53:30 Mario MARIO-OPTIPLEX PageOpen InstallCompleteDialog
2014/9/26:09:55:19 Mario MARIO-OPTIPLEX === Setup ended ===
2014/9/26:11:36:42 Mario MARIO-OPTIPLEX === Setup started on MARIO-OPTIPLEX by Mario ===
2014/9/26:11:36:42 Mario MARIO-OPTIPLEX Path_Length: 152
2014/9/26:11:36:42 Mario MARIO-OPTIPLEX Current Directory C:\Autodesk\AutoCADLT_2015_SWL_English_Win_64bit_dlm
2014/9/26:11:36:42 Mario MARIO-OPTIPLEX Launch
2014/9/26:11:36:42 Mario MARIO-OPTIPLEX CommandLine
2014/9/26:11:36:42 Mario MARIO-OPTIPLEX Current Directory C:\Users\Mario\AppData\Local\Temp\_AI8A94.tmp
2014/9/26:11:36:48 Mario MARIO-OPTIPLEX === Setup ended ===
2014/9/26:11:36:43 Mario MARIO-OPTIPLEX === Setup started on MARIO-OPTIPLEX by Mario ===
2014/9/26:11:36:43 Mario MARIO-OPTIPLEX Path_Length: 152
2014/9/26:11:36:43 Mario MARIO-OPTIPLEX Current Directory C:\Users\Mario\AppData\Local\Temp\_AI8A94.tmp
2014/9/26:11:36:43 Mario MARIO-OPTIPLEX Launch
2014/9/26:11:36:43 Mario MARIO-OPTIPLEX Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Mario\AppData\Local\Temp\_AI8A94.tmp\Setup\AcSetup.dll
2014/9/26:11:36:43 Mario MARIO-OPTIPLEX Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/9/26:11:36:45 Mario MARIO-OPTIPLEX PageOpen LaunchDialog
2014/9/26:11:37:33 Mario MARIO-OPTIPLEX PageOpen LicenseDialog
2014/9/26:11:37:37 Mario MARIO-OPTIPLEX PageOpen ProductInfoDialog
2014/9/26:11:37:43 Mario MARIO-OPTIPLEX PageOpen ProductSelectionDialog2
2014/9/26:11:42:28 Mario MARIO-OPTIPLEX PageOpen FullProgressDialog
2014/9/26:11:42:46 Mario MARIO-OPTIPLEX Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\AutoCADLT_2015_SWL_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2014/9/26:11:42:48 Mario MARIO-OPTIPLEX Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2014/9/26:11:42:49 Mario MARIO-OPTIPLEX PageOpen InstallCompleteDialog
2014/9/26:11:44:07 Mario MARIO-OPTIPLEX === Setup ended ===
2014/9/26:14:08:11 Mario MARIO-OPTIPLEX === Setup started on MARIO-OPTIPLEX by Mario ===
2014/9/26:14:08:11 Mario MARIO-OPTIPLEX Path_Length: 152
2014/9/26:14:08:11 Mario MARIO-OPTIPLEX Current Directory C:\Autodesk\AutoCADLT_2015_SWL_English_Win_64bit_dlm
2014/9/26:14:08:11 Mario MARIO-OPTIPLEX Launch
2014/9/26:14:08:11 Mario MARIO-OPTIPLEX CommandLine
2014/9/26:14:08:11 Mario MARIO-OPTIPLEX Current Directory C:\Users\Mario\AppData\Local\Temp\_AI3A94.tmp
2014/9/26:14:08:21 Mario MARIO-OPTIPLEX === Setup ended ===
2014/9/26:14:08:13 Mario MARIO-OPTIPLEX === Setup started on MARIO-OPTIPLEX by Mario ===
2014/9/26:14:08:13 Mario MARIO-OPTIPLEX Path_Length: 152
2014/9/26:14:08:13 Mario MARIO-OPTIPLEX Current Directory C:\Users\Mario\AppData\Local\Temp\_AI3A94.tmp
2014/9/26:14:08:13 Mario MARIO-OPTIPLEX Launch
2014/9/26:14:08:16 Mario MARIO-OPTIPLEX Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Mario\AppData\Local\Temp\_AI3A94.tmp\Setup\AcSetup.dll
2014/9/26:14:08:16 Mario MARIO-OPTIPLEX Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/9/26:14:08:21 Mario MARIO-OPTIPLEX PageOpen LaunchDialog
2014/9/26:14:08:52 Mario MARIO-OPTIPLEX PageOpen LicenseDialog
2014/9/26:14:08:57 Mario MARIO-OPTIPLEX PageOpen ProductInfoDialog
2014/9/26:14:09:02 Mario MARIO-OPTIPLEX PageOpen ProductSelectionDialog2
2014/9/26:14:09:06 Mario MARIO-OPTIPLEX PageOpen FullProgressDialog
2014/9/26:14:09:06 Mario MARIO-OPTIPLEX Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\AutoCADLT_2015_SWL_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2014/9/26:14:09:09 Mario MARIO-OPTIPLEX Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
