AutoCAD 2013/2014/2015
New Member
0 Kudos
Post 1 of 8
CAN't INSTALL AUTOCAD 2013
5418 Views, 7 Replies
09-10-2012 03:03 AM
Hello, I've tried installing autocad but keep getting this error. Already installed framework 4.5. Don't know what to do. Help Please!!!
2012/9/4:13:48:13 Eduardo MASTERMIND === Setup started on MASTERMIND by Eduardo ===
2012/9/4:13:48:13 Eduardo MASTERMIND Launch
2012/9/4:13:48:13 Eduardo MASTERMIND CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-19177673 /PK 001E1 /student /skipEULA /akamai /auth /sid
2012/9/4:13:52:56 Eduardo MASTERMIND === Setup ended ===
2012/9/4:13:49:49 Eduardo MASTERMIND Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2012/9/4:13:52:55 Eduardo MASTERMIND Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2012/9/4:13:52:56 Eduardo MASTERMIND PageOpen LaunchDialog
2012/9/4:13:53:54 Eduardo MASTERMIND PageOpen LicenseDialog
2012/9/4:13:53:54 Eduardo MASTERMIND PageOpen ProductSelectionDialog2
2012/9/4:13:54:05 Eduardo MASTERMIND PageOpen LicenseDialog
2012/9/4:13:54:05 Eduardo MASTERMIND PageOpen LaunchDialog
2012/9/4:13:54:18 Eduardo MASTERMIND PageOpen LicenseDialog
2012/9/4:13:54:18 Eduardo MASTERMIND PageOpen ProductInfoDialog
2012/9/4:13:54:18 Eduardo MASTERMIND PageOpen ProductSelectionDialog2
2012/9/4:13:54:30 Eduardo MASTERMIND PageOpen FullProgressDialog
2012/9/4:13:54:32 Eduardo MASTERMIND Download Play DOTNET4LANG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DOT...
2012/9/4:13:58:51 Eduardo MASTERMIND Download Complete DOTNET4LANG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DOT...
2012/9/4:13:58:51 Eduardo MASTERMIND Installing .NET Framework Runtime 4.0 Language Pack: C:\Autodesk\WI\AutoCAD 2013\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1034.exe /q
2012/9/4:14:00:04 Eduardo MASTERMIND Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2012/9/4:14:00:05 Eduardo MASTERMIND PageOpen InstallCompleteDialog
2012/9/4:15:14:02 Eduardo MASTERMIND === Setup ended ===
2012/9/4:17:30:31 Eduardo MASTERMIND === Setup started on MASTERMIND by Eduardo ===
2012/9/4:17:30:31 Eduardo MASTERMIND Launch
2012/9/4:17:30:37 Eduardo MASTERMIND === Setup ended ===
2012/9/4:17:30:28 Eduardo MASTERMIND === Setup started on MASTERMIND by Eduardo ===
2012/9/4:17:30:28 Eduardo MASTERMIND Launch
2012/9/4:17:30:28 Eduardo MASTERMIND CommandLine
2012/9/4:17:30:38 Eduardo MASTERMIND === Setup ended ===
2012/9/4:17:31:59 Eduardo MASTERMIND === Setup started on MASTERMIND by Eduardo ===
2012/9/4:17:31:59 Eduardo MASTERMIND Launch
2012/9/4:17:32:02 Eduardo MASTERMIND === Setup ended ===
2012/9/4:17:31:59 Eduardo MASTERMIND CommandLine
*Expert Elite*
1,210 Kudos
Post 2 of 8
Re: CAN't INSTALL AUTOCAD 2013
09-10-2012 03:09 AM in reply to: tosh500
AutoCAD 2013 does not need 4.5, it uses 4.0!
>> [...] CommandLine /url "http://student[...]
Have you downloaded the EXE first or did you start the EXE direct from internet?
First download it to your local drive, then login as adminstrator, disable all antivirus-sw/defender/...other protecting software and start the exe from your local drive.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
New Member
0 Kudos
Post 3 of 8
09-17-2012 11:08 AM in reply to: Alfred.NESWADBA
I have the exe file. I tried everything but still doesn't let me.
*Expert Elite*
1,210 Kudos
Post 4 of 8
09-17-2012 11:21 AM in reply to: tosh500
What EXE-file? The one you downloaded? Then try to uncompress it using WinZIP or WinRAR or 7z. If that works then you've got a directory with the content of the setup-media ==> there you'll find a SETUP.EXE ==> right-click it and start it "as Administrator"
If that didn't work then let us know what didn't work! It does not start, it starts but crashes, it starts but gives some error-messages, .... And at least a log-file should be generated ==> upload this log-file here.
Good luck, - alfred -
Alfred NESWADBA
*Expert Elite*
2,126 Kudos
Post 5 of 8
09-17-2012 11:46 AM in reply to: tosh500
tosh500 wrote:
Hello, I've tried installing autocad but keep getting this error. http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DOT...
Something doesn't make sense here.
The process is:
Download the compressed install files.
Extract (self-extracting) the downloaded install files.
Go to the extracted install files and start the installation exe.
Post screen shots of these files/folders
the download file
the install exe
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
*Expert Elite*
2,126 Kudos
Post 6 of 8
09-18-2012 09:03 AM in reply to: JDMather
Did you solve this problem?
New Member
0 Kudos
Post 7 of 8
08-09-2013 01:31 AM in reply to: tosh500
2013/8/9:16:13:07 User1 USER === Setup started on USER by User1 ===
2013/8/9:16:13:07 User1 USER Path_Length: 155
2013/8/9:16:13:07 User1 USER Current Directory C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm
2013/8/9:16:13:07 User1 USER Launch
2013/8/9:16:13:07 User1 USER CommandLine
2013/8/9:16:13:07 User1 USER Current Directory C:\Users\User1\AppData\Local\Temp\_AI6ECC.tmp
2013/8/9:16:13:16 User1 USER === Setup ended ===
2013/8/9:16:13:08 User1 USER === Setup started on USER by User1 ===
2013/8/9:16:13:08 User1 USER Path_Length: 155
2013/8/9:16:13:08 User1 USER Current Directory C:\Users\User1\AppData\Local\Temp\_AI6ECC.tmp
2013/8/9:16:13:08 User1 USER Launch
2013/8/9:16:13:09 User1 USER Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\User1\AppData\Local\Temp\_AI6ECC.tmp\Setup\AcSetup.dll
2013/8/9:16:13:09 User1 USER Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/8/9:16:13:16 User1 USER PageOpen LaunchDialog
2013/8/9:16:13:21 User1 USER PageOpen LicenseDialog
2013/8/9:16:13:26 User1 USER PageOpen ProductInfoDialog
2013/8/9:16:18:30 User1 USER PageOpen ProductSelectionDialog2
2013/8/9:16:18:34 User1 USER PageOpen FullProgressDialog
2013/8/9:16:18:34 User1 USER Installing .NET Framework Runtime 4.0 Language Pack: "C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe" /q
2013/8/9:16:18:40 User1 USER Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
what can i do???mine is win8
*Expert Elite*
1,210 Kudos
Post 8 of 8
08-09-2013 01:42 AM in reply to: yqwyap
First of all, AutoCAD 2014 is released for Win8, not 2013 (even when there is a SP2 that makes it "more compatible").
So by any chance ... get 2014 (if you have subscription you already have access to it via subscription center).
Seems like you don't have enough permissions on that system. You need to login as administrator and start the setup with right-click and option "run as administrator", you have to turn of antivirus software (and other defending apps).
You might also try to start the Framework setup directly before installing AutoCAD:
Alfred NESWADBA
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
