I am having a problem drawing lines by entering coordinates. I only get perfectly horizontal and vertical lines. ORTHOMODE is off and I can draw at any angle I like if I do it graphically but I can't do it with manual entry.
try disabling DYN, Dynamic Input, and see if that allows you to draw as expected.
Are you using absolute entry #x,y,z (with preceeding # symbol)
or are you using relative entry @x,y,z (with preceeding @ symbol)
Can you attach dwg file that exhibits this behavior and
screen capture of F2 of your sequence?
There is only DYNMODE and DYNPROMPT so I set both to 0. No change.
If I use a # before the coordinates I get "2D point or option keyword required"
But even if it was doing something with relative coordinates I shouldn't get a horizontal line.
Also, sometimes when I hit enter to finish drawing the line the whole thing dissapears.
I must say I just had trouble with IMATCH that was insisting on relative coordinates. How do I disable that? Why would I get that when I have always been able to use absolute coordinates before?
@Anonymous wrote:screen capture of F2 of your sequence?
Not sure, what is that? This is just a blank drawing. I need 2 lines in it based on a set of coordinates. The first line is 0,0 to 2306851,-9951.
I have just typed in your coordinates to draw the line. When I typed 0,0 to 2306851,-9951 the line looks horizontal. When I draw a line back from the end point across to the start point of 0,0 the line is infact at an angle and when I 'id' the points the coordinates are correct. Could it be that the line just looks horizontal?
These are mutually exclusive statements. You cannot have both a blank file and with "perfectly" horizontal and vertical lines.
If you had attach your dwg here with the first post - you would have had your solution given in first response.
Using the coordinates your supplied - I get a line at an angle of 0.24715° from "perfectly" horizontal.
Just out of curiosity - what are your intended units?
Not really. If you take a new, blank drawing and then draw lines in it you will get what I was trying. I could have uploaded a new, blank drawing but it's easer for you to press press Ctrl-N.
Thanks TashaCAD, the angle is completley off so obviously the coords are wrong. I couldn't zoom very well so I missed it entirely. Thanks for taking it back to basics.
Thanks TashaCThanks TashaCADA
