I was working in Autocad 2015 today and all of a sudden I started experiencing a few problems:
- I can't access layer properties. When i click the button in the ribbon menu I don't get the popup-window but rather just a list where it says "make new", "delete" and a whole lot of other comands.
- I can't make blocks. When I select an area and write Block or press the button on the ribbon menu I get a text where it says "specify a name" and then "specify an isertion point". I never get the pop-up window where you can name your layer and all the other setings.
- When I select an area and type in group I the program tells me to specify a name and category for the group. It does group the lines together but that's not how the group-cpmmand is suppose to work.
I have no ides what i have done or if I have unintentionnaly pressed some button. Have anyone experienced this? How do i fix it?
