I am unable to load or add the "Workspace 3D Modeling" cui to the Workspace drop down selection list.
I am using AutoCAD MEP 2014.
Anyone have a solution for me?
Thanks in advance for your help.
Solved by nestly2. Go to Solution.
Solved by pendean. Go to Solution.
3D modeling will already be available if you run as "AutoCAD" rather than "AutoCAD MEP"
Tools > Options > Profiles tab > AutoCAD > Set Current > Apply
... or do you need to have the 3D modeling workspace within the MEP environment?
Where or how are you "trying" to do this exactly? In CUI Customization Menu
And which AutoCAD profile are you currently running in MEP2014? here is more than one. AutoCAD MEP (US Imperial)
Lastly, are you allowed by your IT or CAD Manager to edit your CUIx file like that? ask at your end if you don't know. Yes
Your Questions were part of the solution. The other respondent also helped solve my problem.
Thanks a bunch!!
Nestly2, your comments and questions:
Good question. I'm checking to see if there any additional features in 3D Modeling as compared to just running MEP.
Your Comments & Question(s) were part of the solution.
Thanks a bunch!!
Both of you are great!!
