AutoCAD Forum
can Install NLM and autocad 2013 on virtual server
6 REPLIES 6
pritcad
5672 Views, 6 Replies
We installed autocad 2013 network license on server and able to access from client machine. However, we are unable to access license from server itself.
It is virtual server with windows 2008.
Regards
Pritam
6 REPLIES 6
rkmcswain
in reply to: pritcad
Are you saying that the client machines can ping and otherwise communicate with the LM, but AutoCAD will not get a license from there? What error code are you seeing on the client end?
braudpat
in reply to: rkmcswain
Hello from France
The FlexLM can run on a VMware and ACAD 20xx can run on an other VMWare
If the 2 VMWares can communicate and ping themself and if the DNS Server is OK
and if there is no restrictions with a hardware/software Firewall, it must run ...
Are all Ports open ?
Especially : 27000-27009 & 27080
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
pritcad
inchul.lee
Hi pritcad,
This kind of question is better handled in the Installation & Licensing Forum, but let me provide you some information:
First of all, AutoCAD 2013 is supported on the client OS but not the server OS. Please refer to AutoCAD 2013 System Requirements.
Secondly, if you're running the License Manager on virtual machines, please refer to
2014: Network License Manager System Requirements.
Thirdly, if AutoCAD 2013 installed on the server itself can't get a license, then first check LICPATH.LIC file in the installation folder (ex. C:\Program Files\Autodesk\AutoCAD 2014) and see if it's pointing to the right address (ex. localhost or 127.0.0.1).
Thank you.
Inchul Lee
rkmcswain
 Control Panel > System > Advanced > Environment Variables
Add a System Variable named ADSKFLEX_LICENSE_FILE
Make the value of this variable = the name of your LM preceeded with an "@" sign (for example: @MYLM )
More info here: http://cadpanacea.com/node/43
TravisNave
Installation of AutoCAD on your server is not supported and it is a license violation due to the fact that it is potentially possible to access the installation from a remote terminal.  If you wish to provide this sort of service, then you need a supported Citrix solution.
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=13959101
Good Luck!
Autodesk Forums:
”Boost
