AutoCAD 2013/2014/2015
Active Member
marceldenbakker
Message 1 of 15 (3,860 Views)
Accepted Solution
Can i easy change the color af all elements into one color in a block?
3860 Views, 14 Replies
09-04-2012 02:41 AM
How can i easy change the layer colors of all elements in a block and also the blocks in that block witout exploding everything ten times. I wish Autodesk create a button so if you select a block and use the button i had a choyce to
select a layer or color. Looks so simple.
* setbylayer is not what i mean
* also dont want to use xrefs
I hope someone can help me.
Distinguished Mentor
steven-g
Message 2 of 15 (3,851 Views)
Re: Can i easy change the color af all elements into one color in a block?
09-04-2012 03:06 AM in reply to: marceldenbakker
Create a new drawing with only layer 0; Insert your block into the new drawing. All the layers will show up in your layer properties manager. Make the changes you want in the layer properties manager. Open design center and go to the open drawings, make your old drawing the current one,select the block from the new drawing and right click - select redifine only. And all the blocks in your old drawing will be updated to the new layers.
Regards Steven Gray
Setting Out (Joinery Manufacturing)
Autocad 2013LT
Windows 7 professional
Active Member
marceldenbakker
Message 3 of 15 (3,846 Views)
09-04-2012 03:28 AM in reply to: steven-g
Thanks for your reply,
But it dont work in my drawing. In my drawing all layers that are in the block already been used in the drawing. So if i changes the layer colors in the new drawing (of the block) and i insert the block in my drawing all layers are the same colors. Not gray.
And i think is takes too much time to do this all. I hope theres a more easy way to do this.
But thanks!
steven-g
Message 4 of 15 (3,843 Views)
09-04-2012 03:59 AM in reply to: marceldenbakker
If you insert the block, it will take on the properties of the existing block in the drawing again. That is why you need to take it out of the drawing and make the changes and then use redifine not insert.
And by the way once in your new drawing you can open the layer manager press Ctrl+A to select all the layers, click on any one of the colour properties, and they all change.
Regards Steven Gray
Autocad 2013LT
Active Member
marceldenbakker
Message 5 of 15 (3,841 Views)
09-04-2012 04:19 AM in reply to: steven-g
Thanks. Now i redefine and all layers changed into grey. But allso te same layers who already where in the drawing. They all turn grey. I only want to change the color of the block. Is that possible ?
*Expert Elite*
3wood
Message 6 of 15 (3,832 Views)
09-04-2012 05:32 AM in reply to: marceldenbakker
You can change all entities in the block to BYBLOCK color, the assign a special color to the block itself.
Edited by
Discussion_Admin
steven-g
Message 7 of 15 (3,827 Views)
09-04-2012 06:14 AM in reply to: marceldenbakker
I think it will have to be the hard way. going into each level of your block and change everything to layer "0" then you can put the block on it's own layer and choose the colour on that layer. Someone may be able to help you do that with a lisp routine.
Regards Steven Gray
Autocad 2013LT
Active Member
marceldenbakker
Message 8 of 15 (3,797 Views)
09-05-2012 12:42 AM in reply to: steven-g
Yes it think thats the only way. A lisp can be a solution.
I was thinking if i could use a transparant mask or something like that, to lay over the block?But then i have to do that with a hatch en make ik transparant. But when i look in the printpreview the block isnt vissible anymore.
Active Contributor
wundrlik
Message 9 of 15 (3,786 Views)
09-05-2012 08:16 AM in reply to: marceldenbakker
Here's a lisp routine that I've used for years.  I can't remember where I first found it, but I've modified the code from the initial inception.  It will change the geometry in any block to Layer 0, and changes the color to BYLAYER.  It also works on anything with a truecolor assigned.
Hope that helps
Ryan A Wunderlich
Royal Caribbean Cruises Ltd.
*Expert Elite*
drjohn
Message 10 of 15 (3,776 Views)
09-05-2012 09:13 AM in reply to: marceldenbakker
Make sure to tick PLOTTRANSPARENCY in the plot dialog box to plot transparency
Wouldn't refedit be applicable here assuming there is only one block of that name in the dwg?
Announcements
Need installation help?
