I try to open a file to Erase a object which is a block named GEMLOGO, then Purge_all in the drawing and Svae & Close. Can anyone help me to write a script file? so i can run this file throughout a set of drawings.
Peter
Solved by abubakars. Go to Solution.
Peter,
Check this below post
http://forums.autodesk.com/t5/AutoCAD-2013-2014-2015/custom-Plot-Stamp-amp-publish/td-p/5195263
