AutoCAD Forum
calculating values on the fly
7 REPLIES 7
Message 1 of 8
immunoman
565 Views, 7 Replies
A fundamental question that comes across regularly is calculating values for offset distances, move, radii, etc. If I want to calculate a value of .5 the interface does not accept 1/2 as a valid entry. Can someone explain this basic function to me?
7 REPLIES 7
Message 2 of 8
jggerth1
in reply to: immunoman
Does not 0.5 work as input?  or are you talking about half the distance between two points?
If the latter, then (* 0.5 (getdist)) will let you pick two points and return half the distance between then.
If you want to use arbitrary fractions, then command line lisp is also handy,  the expression would be (/ 1 2.0), or (/ 4 5.0)
(one of the numbers always needs to be a real, or the result will be an integer, (/ 1.2) returns 0 instead of 0.5)
Or, you can explore the CAL command for another variant.
Message 3 of 8
immunoman
in reply to: jggerth1
It seems 'cal is the way to make it work
Message 4 of 8
neilyj666
the transparent M2P will allow you to pick a midpoint between two pick points
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 5 of 8
heinsite
in reply to: neilyj666
M2P ijust might be on the top of my favorite commands list!
Smiley Wink
Dave.
Dave Hein, P.E.
Message 6 of 8
neilyj666
in reply to: heinsite
It's certainly up there in my favourites...:)
Message 7 of 8
immunoman
I thought 'cal was the answer to calculating values while creating accurate geometry. It doe not seem to work however when prompted for x,y coordinates when I tried using it in the offset comman.Smiley Mad
Message 8 of 8
dbroad
Works fine for me. Perhaps a little more process information from you might help us guess how and what you are doing.
For me, if using through option:
Offset <enter to pick through><pick object>'cal (nea+cur)/2<enter><pick><pick>
For me, if using the distance option:
Offset 'cal<enter>dist(nea,cur)/2<enter><pick object><pick side>
Of course, the formula you choose to use could virtually anything.
Architect, Registered NC, VA, SC, & GA.
”Boost
