AutoCAD 2013/2014/2015
Active Contributor
JF_005
Message 1 of 3 (375 Views)
Bug: Command Line appears again after Plot command
375 Views, 2 Replies
05-15-2012 09:50 AM
I press CTRL+9 to make the Command Line disappear while drawing. When I plot (or when doing a plot preview) , the Command Line appears again by itself. So I always have to turn the Command Line off manually after each plot - which is annoying.
The bug still happens;
- if Dynamic Input is turned off or on
- if I plot to a real device or in PDF
- if the Cammand Line Palette i docked or floating.
This is not an issue in AutoCAD 2012 so I guess it has to do with the new way they programmed the revamped Command Line palette in 2013.
Using Windows7
Any suggestions?
Thank you for the workaround! Still I hope Autodesk would fix this.
rkmcswain
Message 2 of 3 (372 Views)
Re: Bug: Command Line appears again after Plot command
05-15-2012 09:57 AM in reply to: JF_005
This problem was posted earlier, with a couple of suggestions.
Active Contributor
JF_005
Message 3 of 3 (366 Views)
05-15-2012 10:46 AM in reply to: rkmcswain
