We rencently upgraded our systems to either AutoCAD 2015 or AutoCAD LT 2015. On machines that the software was installed from that system, there is no issue. On machines that the software was installed through a deployment, there is a Tools > License Borrowing > Borrow License option. All systems were upgraded with the Stand Alone option and the Product License Information dialog box shows the License Type as Standalone-locked. Selecting the Borrow License option has no apparent affect and the AutoCAD Text Window just shows another Command prompt afterward.
Is there a reason that this would happen and are there any ramifications?
Hi Duncan,
Thank you for the reply. We are not trying to borrow any licences; we have a license for every system that ACAD is installed on and don't use/need a license manager. My question is: Why do we have that option, given that it was a standalone installation? This only occurs on machines where the install was done through a deployment and not on the machines that the installation was done by an administrator sitting at the keyboard. Why do the users have the ability to borrow a license when their ACAD is already up and running. I'm concerned that this may inject an instability into the system and may require a reinstall.
Any suggestions?
I'd be curious if in fact the deployment was setup correctly as a stand-alone install - but I have no experience setting up deployments so who knows.
You might have better luck in the Licensing and Installation forum;
http://forums.autodesk.com/t5/installation-licensing/bd-p/24
