Regarding the blue hatches that appear on the Layer Properties Manager V2015 over some of the Layer's names, what are these and how are these turned off?
Thanks in advance.
Solved by octavio2. Go to Solution.
Solved by rkmcswain. Go to Solution.
Or if you do not want to remove the viewport overrides, but only want to remove the blue shading, you could set the shading color = to the color of the background of the layer manager.
Look for the gear icon inside of the layer manager to access this.
Thanks for the information.
I personally find that "strong" blue color a little visually distracting and offensive, and I tried to work with the "transparency" of the Layers Manager to no avail.
Is there a way to make that "strong' informative blue (but visually intrusive) a little less strong?
Thanks, rkmcswain.
I answered to Nestly2 before I saw your post, and when I then saw yours, I looked for the gear icon and changed it to a lighter blue 200,228,244 which seems more pleasant to the eyes.
Again, thanks to You and to Nestrly2 for the responses.
