When using the block editor to rename an existing block to clean that instance of the block name out of the file, the block replace command from express tools does not work.
I select a block enter block editor save block as (new Name) save and exit block editor.
Insert new block into the drawing.
Express tab on the ribbon select Replace Block select block A to be replaced by Block B purge out instance of block A after complete. It reports 0 blocks replaced
attached is a file with 2 blocks called Drain and Drain X each have the same visibility states I want to replace Drain with Drain X to purge out Drain from my file.
Any Ideas?
Solved by kadmonkee8. Go to Solution.
Hello from France
Just a stupid idea !
Unfortunately some Express Tools are not working correctly with Dynamic Blocks : BCOUNT, ATTIN/ATTOUT, etc
and may be also the Block Replace ???
Bye, Pat
PS for Pendean : thks for the confirmation !
Patrice BRAUD
Hello from France
So you will find a ZIP attached file with a marvellous French routine : RBLOC
which is much more powerful than the old Replace Block (from Express)
and it supports Dynamic Blocs & Attributes (if I remember well) !
The Routine is 2 files : LSP + DCL
So you will have to add to your Support Folders the folder where you will place the 2 files
OR you can place the 2 files INTO your ACAD folder ...
Thks to Patrick : a high level Lisp/VLisp french developper !
A lot of people are using this nice routine in France and some other countries ...
If the French options/texts are too "dark" for you
let me know, I will try to explain ...
or I will dot a fast translation of the DCL/LSP ...
ATTENTION : I have not tested it on an US/English ACAD !
So maybe you could have problem ! Please let me know ?
Please enjoy, Bye, Pat
Patrice BRAUD
Here's an alternate workflow idea:
1. Create your updated/revised block in a separate dwg (we'll call it the "source" dwg); keep the block name the same as the name in the "destination" dwg.
2. With both the "source" and the "destination" dwgs open, open DesignCenter, click the "Open Drawings" tab, go to the Blocks section of the "source" dwg, find the new version of the block in the right-hand pane, right-click it and select "insert and redefine".
Does that get you what you want (and maybe save some steps, too)?
(P.S. Step 1a. Be sure to save the "source" dwg before proceeding to step 2.)
(P.P.S. Perhaps this is obvious, but in step 2, the "destination dwg" must be "current".)
that does work Thank you
this can be dangerous in the wrong hands though.
Dynamic blocks w/ visibility states and action parameters could become lost or damaged
I will need to play with this some more to explain it to the users in the office.
thanks again
Hello
Please (just for my Info) which solution is OK for you ?
- dmfrazier procedure ?
or
- RBLOC french routine ?
Bye, Pat
Patrice BRAUD
i went with dmfrazier's procedure
it seemed less intrusive
especially since the lisp / dcl has not been tested in the english version yet.
thank you for your suggestion
i will test it at a later time though
@kadmonkee8 wrote:...this can be dangerous in the wrong hands though.
Yes, any useful, powerful tool can be dangerous if not used properly. Users must be trained in the downsides as well as the upsides.
In addition to making certain maintenance tasks easier, you will eventually discover that another advantage of using block "source" dwgs is in developing standard tool palettes for inserting the blocks.
Glad I could help.
Hello Everybody
I will appreciate if somebody could test a little bit
the French RBLOC routine on it's English / German / Spanish / etc AutoCAD 201X ...
Thks, Bye, Pat
Patrice BRAUD
Hello
THKS Mr Pendean
I appreciate your test and I can do a minimum translation if you estimate it's necessary to use it easily !
This nice routine (with many options) from Patrick_35 (cadxp.com - a very popular CAD french forum)
is used by a lot of french people, so it could interest other people
I have too (from an other french developper Bryce always on cadxp.com) a GOOD ATTIN / ATTOUT routine
which support dynamic blocs ...
Thks again, Bye, Pat
PS: a stupid french question, what does mean the term OP please ?
Patrice BRAUD
Hi kadmonkee8,
I have just created a video demonstrating your issue, the Block replace using Free tool "BatchInDatabase" available in Autodesk Exchange App to download.
http://www.youtube.com/watch?v=mmC_vPc6MHM&feature=youtu.be
In most cases, OP is used as an abbreviation for Original Poster (the author of the question).
In our company it stands for Order Processing, so I am frequently confused (usually only momentarily, though ).
Thank you for the video
it does work for block replace, but I need it to also recognize the visibility states in the dynamic blocks
apparently AutoCAD 2014 does not like Dynamic blocks in this manner
Autodesk is looking into a solution for this to happen.
Dynamic blocks respond well in the vertical Autodesk application but not the basic generic flavor of AutoCAD
Hello
Thks for the OP Info
Now I am ready to contribute for OP ( = Other People) !
Bye, Pat
Patrice BRAUD
