HI.
Please see attached picture.
Problem is basiacly when I insert/paste block containing text or text into the model space. If I paste it on any line object seems to be blur-ish but when I paste it not on the line it;s ok - why is that? Any option?
Regards
CEZ
If the line has a Z coordinate that is not zero then the text will look fuzzy.
Highlight the text and check the properties palette to see if the Z position is not 0. (You may have to change your units and precision because it could round a very small number to 0 when its not really 0. Just type a 0 in the box and hit enter to fix it.)
Thanks for that
But can I look it position Z to default 0 so it won't happen again when I insert or paste block or MText? Or do I have to do it every time - change position Z to 0 if it's different after I have pasted it?
