I recently upgraded to ACAD 2015 & have found that the Block Editor Command Bar remains visable after closing the Block Editor. Its an annoyance that has finally got me - has anyone else experienced this bug & is there a solution?
MK
Solved by Jason.Piercey. Go to Solution.
Solved by mk. Go to Solution.
I get this, as do others based on posts here. Quite annoying. No fix that I am aware of.
You're welcome. You can also switch file tabs within AutoCAD and it will disappear, both options are work-arounds. I guess what I menat by "fix" was to keep it from happening in the first place. Hopefully 2016 will not suffer the same issue.
This should have been fixed after installing the Service Pack #2 for 2015 software. It should also be fixed in 2016 software.
It was a problem with migrating profiles.
If you have installed the service pack #2 and are still running into it, let me know here and I can reopen the problem report.
Visit knowledge.autodesk.com for service pack information.
