AutoCAD Forum
Block Base Point - Tool Pallette
2 REPLIES 2
282 Views, 2 Replies
I have a library of blocks contained in one drawing with a set base point which has been defined using Block Editor (pick point).  When I copy / paste these blocks in to another drawing, the base point is kept.
However, when I move the blocks in to the Tool Pallette and insert into another drawing, the base point changes to a point miles away.  I know it's possible to keep the same base point as I've seen it done in other tool pallettes, but for the life of me I can't work out how this is done.
Would anyone be able to provide some guidance?  I'm running AutoCAD 2015.
Thanks so much in advance,
Clare
2 REPLIES 2
pendean
Is this problem limited to one file?
What if you stat a blank new file and drag from TP?
in reply to: pendean
Hi Dean,
It happens regardless of whether I use a new file or an existing one when draqgging from TP in to drawing.
However, if I create a new drawing and create some "test" blocks, and follow the same procedure (choose pick point, copy to TP, copy in to another drawing), the problem doesn't reoccur - I assume it's a setting I have in my block library but not sure what setting to look for.  I still have the same issue if I select all blocks and copy them in to a blank file.
Hope that clarifies a bit better.
Thanks again,
Clare
”Boost
