I'm having a slight issue with attributes within blocks.
I have all the attributes set to a annotative text style justified to bottom-center. When inserted, the block preview shows all the text justified to the left (below-right). After I click, the text regains it's normal bottom-center justification (below-left).
I have tags for our office arranged in a tool palette, which shows an even weirder effect, probably because the text is annotative:
Is there a way to fix this so the bottom-center alignment is shown in both the block previous upon insertion and the tool palette icon?
This is what the block .dwg itself looks like with all bottom-center justifications:
You are correct, the block being shown incorrectly in my tool palette is the problem. Your also correct that AutoCAD justifies the text after insert. Are there any known workaround for getting tool palette block previews to display correctly w/ justified attributes?
i reworked the block so that the Attributes are no longer Annotative and the justification and position are Middle Center and locked
paper space text height for Anotative blocks is set for 3/32" so the geometry has also been reduced
the Block itself is Annotative
we use annotative blocks for all kinds of symbols and typically we create them 1:1 and allow the anno scale to adjust accordingly
i renamed the file for testing on your end if you like just rename to overwrite for your tool palette container.
I hope this helps
Hey man, I really appreciate all your work on this. I'm having trouble with it, though.
It would seem that the annotative block doesn't scale itself.
Here are the original and your block at 1/4" scale:
And again at 1/8" scale:
The annotative text scales, but your entire block does not scale.
Also, for those interested, the block display in the tool palette is pretty close, but still justifies to the left as opposed to the center:
no problem
if you turn the system variable (selectionannodisplay) on 1= on 0 = off and select my version of the block you should see a ghosted image of the inactive scale
linework is not annotative but the block is adjusting as you change scales.
another check you can try in your properties dialog box under Misc check what Annotative scales are associated with that block - should be 1/8" and 1/4" based on my image your test may vary but match settings to confirm things are working properly
see images attached.
