Currently looking for the best was to move the viewport settings (freeze/thaw, color overide) between layout tabs. I am familiar with Layer States, but it overrides everything, if I make a master change, then that viewport does not see that change. I only want to override the the layers that I changed. So if I color overrided 25 layers, I only want those 25 layers to show as viewport overridden.
My current work around is this. LayoutA (has the settings I need) and LayoutB (is awaiting the new settings). I do a layout copy of LayoutA, then move all info to the side of the page, then I copy and paste in the info from LayoutB into LayoutA(copy), then I do a match properties from LayoutA viewport to the LayoutA(copy) viewport. I then rename LayoutA(copy) to Layout B.
Why not just initially create layout tab B with a copy of layout A along with the layer states? Why create a generic tab, unformatted to layer states, THEN try to format with your work around?
