AutoCAD Forum
Best way to move viewport settings between layout tabs?
5 REPLIES 5
claimed4all
565 Views, 5 Replies
Currently looking for the best was to move the viewport settings (freeze/thaw, color overide) between layout tabs.  I am familiar with Layer States, but it overrides everything, if I make a master change, then that viewport does not see that change.  I only want to override the the layers that I changed.  So if I color overrided 25 layers, I only want those 25 layers to show as viewport overridden.
My current work around is this.  LayoutA (has the settings I need) and LayoutB (is awaiting the new settings).  I do a layout copy of LayoutA, then move all info to the side of the page, then I copy and paste in the info from LayoutB into LayoutA(copy), then I do a match properties from LayoutA viewport to the LayoutA(copy) viewport.  I then rename LayoutA(copy) to Layout B.
5 REPLIES 5
steve216586
in reply to: claimed4all
Why not just initially create layout tab B with a copy of layout A along with the layer states? Why create a generic tab, unformatted to layer states, THEN try to format with your work around?
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
claimed4all
in reply to: steve216586
That's a thought, but problem is sometimes I don't need those specific overrides unit well after LayoutB is created.
kasperwuyts
I'm not really sure i understand the problem 100% correctly. Just copying the ' viewport from LayoutA to LayoutB and do match properties to the LayoutB-viewport does not do what you want?
Best regards
Kasper Wuyts
_______________________________________________________________________________
If this post solves your problem, clicking the 'accept as solution' button would be greatly appreciated.
claimed4all
in reply to: kasperwuyts
When you copy and paste a viewport is loses all of its overrides.
pendean
You seem to have a workable solution: if you want something else you'll need to customize (and pre-plan). Customization forums are here: http://forums.autodesk.com/t5/autocad-customization/ct-p/AutoCADTopic1
”Boost
