AutoCAD Forum
Best way to display a logo in a titleblock
13 REPLIES 13
Message 1 of 14
jpedersen
2451 Views, 13 Replies
Afternoon All,
I have always struggled with the best way to deal with a client logo in our titleblocks.
The way I was shown when I started was to insert the logo file in a new Autocad drawing and trace it using plines, arcs...
The problem: the time involved and it never looks as good as the image.
On several projects we have inserted the logo as a Raster Image Reference and it looks great.
The problem: will not bind when sending drawings out of the office.
What are your thoughts?
Any advice/help would be great!
Autodesk Plant 3D Design Suite Premium 2015
Navisworks Freedom-Sim-Manage 2015
13 REPLIES 13
Message 2 of 14
Patchy
in reply to: jpedersen
Yes, you can bind an image into a drawing.
Message 3 of 14
braudpat
Hello
To send drawings (projects) to somebody else why you don't use the ETransmit feature ?
With ETransmit the main DWG + ALL Xref XREF DWGs, Xref Images, Xref PDFs, etc, FONTs, PC3 drivers, etc will be included in the ETransmit package ...
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 4 of 14
dgorsman
My first preference is always for a CAD object.  If the client hasn't provided one, I get the project lead to poke the client to see if they have one available (they don't always provide it up front).  Failing that, I look at building one using the client logo image.  If the logo is complex, then I go with that.  As for managing a referenced image, well... most clients are savvy enough to handle such things, as the drawings came off their system in the first place.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 5 of 14
jpedersen
in reply to: braudpat
@braudpat wrote:
Hello
Bye, Pat
Pat,
I have used Etransmit in the past on sending out 3 or 4 drawings but isn't convenient when sending a large set of drawings.
Message 6 of 14
jpedersen
in reply to: dgorsman
I didn't think that most clients would have a logo as a CAD object. Most of the time I end up going to their website to get the logo.
Message 7 of 14
jpedersen
in reply to: Patchy
Patchy,
what is your process to bind images into the drawing?
Message 8 of 14
Patchy
Open the image with PAINT
CTRL+A
CTRL+C
Go to autocad and use command PASTESPEC
Use metafile
Message 9 of 14
dmfrazier
in reply to: Patchy
Good catch, Patchy.  (I was just about to suggest "metafile".)
The key here is that this inserts the image as a "Static" OLE object.
Message 10 of 14
Patchy
in reply to: dmfrazier
Smiley Very Happy I goofed for a second.
Message 11 of 14
jpedersen
in reply to: Patchy
CTRL+A
CTRL+C
Use metafile
Good call, good call.
This seems the easiest way.
will try on next project.
Thanks Patchy.
Message 12 of 14
dgorsman
Many do, but almost all drawings go back and forth through a document control department at the behest of engineers - none of which are typically very CAD savvy.  So if you get a stack of drawings (particularly older files) its not uncommon for things like logos, plot styles, and other important stuff (to us, anyways) to get skipped because they only think of DWG files.
The project manager talks to their equivalent in the client company who goes directly to their CAD department.  That ensures we get what we need if it exists.  It also sets up a chain of comminication, such that for clients we've had for a while include us on distribution lists when they do any logo updates.
Message 13 of 14
dmfrazier
I suspect you may already realize this, but you don't necessarily have to use Paint, as any method for getting a "clipboard copy" of the image to "paste special" will work. For example, you can just zoom in on the image (the larger the better) in whatever application allows you to view it and use the Windows Snipping tool to make the copy.
Also note that OLE objects have a "Plot Quality" property/setting that you might have to tweak in certain cases.
Message 14 of 14
Manicbala
in reply to: Patchy
Thanks Patchy.
This one is the easiest way to insert image in drawing.
Bala
”Boost
