I've been receiving the converted 3d DWG files from my subs (creatd in CadMech mostly).
I want to know what's the best way to convert them into true 2d FLAT dwg?
I tried to use the commaned "FLATTEN" and found no success.
Thanks in advance,
Davdi
Solved by maxim_k. Go to Solution.
What is in the file?
Solids?
Surfaces?
Wireframe?
More information is needed, can you attach an example file here?
Unfortunatelly there is no attachment in your post 😞
But anyway, if 3D objects are Solids, than you can try to useFLATSHOT command.
Or you can use VIEWBASE command to create 2D views in Layout, then use EXPORTLAYOUT command to save 2D representation of Layout to separate DWG.
Or you can PLOT to DXB file, then import DXB in new drawing:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2876115&linkID=9240617
The last method works not only with solids, but with all 3D data.
Maxim
Sorry, here is the attached file.
Basically, this is my setup.
My master file has all of the 3d dwg files XREF to it from different trades.
I want to "flatten" all of the 3d dwg files at once. I'm curious if the flatshot works for XREF as well?
Or do I have to BIND the XREF before doing the flatshot?
Thanks in advance.
EXPORTLAYOUT command doesn't work.
After it's done, when I look at the drawing in 3d view, it's still shown as a 3d model, NOT 2d lines.
I want a 3d model to be converted to 2d lines. Even though it looks the same in the plan view, but the file size is a lot smaller for the 2d type of tasks.
@diesellam wrote:
...I want a 3d model to be converted to 2d lines. Even though it looks the same in the plan view, but the file size is a lot smaller for the 2d type of tasks.
Read the often-correct solution posted above, here is the link to it if you cannot scroll up to find it
