AutoCAD Forum
Best computer for Autocad 2015?
33 REPLIES 33
Message 1 of 34
130137 Views, 33 Replies
Hello, I'd like to know what computer do you recommend, that works best with Autocad 2015 please.
Thank you
Astrid Herrera
33 REPLIES 33
Message 2 of 34
JDMather
What is your budget?
CPU
Graphics Card
Screen
Mouse
3D Input?
You might give a bit more information.
File sizes?
Geometry complexity....
Message 3 of 34
braudpat
Hello
Welcome to the Autodesk/AutoCAD Forums !
ACAD 2013/2014/2015 : almost no difference !
Q1) Which kind of drawings : 2D / 3D ?
Q2) Architecture / Schematic / GIS / Mechanical / etc ?
Q3) small / medium / large models/drawings ?
Q4) Budget ?
Can you buy a very fast Core i5 ou Core i7 (Basic Speed > 3.2-3.4 Ghz)
Can you buy 8 Gb Ram or better 16 Gb (if medium/large 2D/3D Models)
Can you buy a graphic card with 2 Gb Ram
Can you bu a primary SSD HD and a secondary fast SATA HD ?
etc
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 4 of 34
in reply to: braudpat
I am needing the same recommendations. What would be a good laptop that would run AutoCAD 2014?
Q1) Which kind of drawings : 2D / 3D ? Mainly 2D for now
Q2) Architecture / Schematic / GIS / Mechanical / etc ? Architectural floor plans and blueprints
Q3) small / medium / large models/drawings ? Not sure yet
Q4) Budget ? Any
Can you buy a very fast Core i5 or Core i7 (Basic Speed > 3.2-3.4 Ghz) Yes
Can you buy 8 GB RAM or better 16 GB (if medium/large 2D/3D Models) Yes
Can you buy a graphic card with 2 Gb Ram? Yes
Can you bu a primary SSD HD and a secondary fast SATA HD ? Possibly.
etc.
Weight is a factor as I am not very strong so I am needing it to be as light as possible.
Message 5 of 34
pendean
Contact Dell, talk to a sales rep, thru can help you configure a system. Write down the specs, go shop around for similar units from other manufacturers. Ask about that configuration here if you want.
Message 6 of 34
braudpat
Hello from France
So: Mainly 2D - Architectural floor plans and blueprints - small / medium / large models/drawings ? Not sure yet - Budget ? Any
So a Dell/HP/etc fast notebook will be OK :
- Fast Core i5 or Core i7 (Basic Speed > 3.0 Ghz - if possible)
- 16 Gb Ram
- 2 Gb Ram (dedicated) graphic card
- Fast Sata HDD or maybe SSD + Fast Sata
Maybe a good Dell Precision M3800, HP Zbook 15/17, etc ...
Screen 15" so the weight be as light as possible ...
Patrice BRAUD
Message 7 of 34
Thank you!
Astrid Herrera
Continental Doors, Inc
Message 8 of 34
I'm going to be using my new laptop for AutoCAD work, creating 2D residential floor plans and blueprints. But also playing games at max settings such as Lord of the Rings Online, ARMA III, Total War series, older games like Age of Empires and Return to Castle Wolfenstein. Also the normal Netflix, internet and Skype etc.
I'm mainly looking at these right now. All suggestions are welcome.
http://www.newegg.com/Product/Product.aspx?Item=34-152-567
http://www.newegg.com/Product/Product.aspx?Item=N82E16834231320
http://www.dell.com/us/business/p/precision-m3800-workstation/pd?oc=CAM3800W7P002
Also, does anyone know where I might be able to get certified as an Architectural Drafter or just as AutoCAD Certified/Drafter al beit online or somwhere in the Ft Worth, Texas area inexpensively? All help is greatly appreciated!!!! I've included some pictures of work that I've done on my own. This is using no templates of any kind. All my own creation.
Message 9 of 34
I am currently studying 3D Design and am searching for the most suitablest or best laptop to work with AutoCad, Illustrator and similar programmes. A great audio experience would be plus since I listen to lots of music and a light machine since I have to carry it around with lots of other stuff.
Although standard recommendation is a Macbook Pro, I am not so convinced since Macs are very expensive and AutoCad appears to run better on Windows.
I was doing some research and came across a number of laptops / brands that have been recommended on some forums.
Please, I would appreciate some advice, recommendations on what machine to buy.
The machines / brands I have found are:
MSI G Series GE70 2OE-017US
CLEVO, costumisable,
DELL costumisable
Minimum recommendation is the spec of a Macbook Pro.
Many thanks 🙂
Message 10 of 34
Macbook Pro 15inch with Retina Display good for Autocad? 🙂
Message 11 of 34
pendean
Look in the MAC forum, retina displays have challenges you need to be aware of...
Message 12 of 34
Dear All,
I am in need help with the lalptop for my AutoCAD 2015.
I am using it for mechanical 3D design.
below is my laptop specification;
Lenovo Thinkpad W540 (Custom made)
W540 FHD WW
Intel Core i7-4900MQ Processor(8MB Cache , up to 3.8 Ghz)
8GB PC3-12800 DDR3L
SDRAM 1600MHz SODIMM (1 DIMM)
500GB7200RPM
DVD Recordable
Nvidia Quadro K2100M
16GBM2SSD
Intel 7260 2x2 AC+Bt4
720p HD Camera / FPR
Smart Card Reader
9cell Cylindrical 99.9Wh
but the problem i am facing is that whenever i try to design and draw in 3D. my laptop always hang, jammed and not working smoothly (laggy).
Can anyone of you please assist me to have a look into my laptop specification. Is there anything I need to change or add in.
Message 13 of 34
braudpat
Hello
A few questions ...
0) Which software exactly ? ACAD ? / Inventor ?
1) Your processor "Intel Core i7-4900MQ" is OK and fast and modern - 4 Cores/8 Threads / 2.8-3.8 Ghz / 8 Mb cache ?
2) 8 Gb Ram could be not enough for medium/large 3D models - 16 Gb will be better ?
3) Is your graphic card : a K2100M with 2 GB GDDR5 ? - For me this card is OK !
Waiting ...
Patrice BRAUD
Message 14 of 34
Hi braudpat
The software I'm using is ACAD only.
Yes that is my processor
Yes the graphic is just like what you had describe
But still when draw in 2 d model, it is working smooth.
Once I try to draw in 3d model. The whole laptop either jam which I had to force restart, when drawing the cursor is not moving smoothly, or it keep the software is not running do I want to terminate it.
This really give me a hard time ad I spent quite a huge money on this laptop.
Other than the ram is there anything else I need to modify?
Your advice is truly appreciated
Message 15 of 34
braudpat
Hello
This notebook is OK even if 16 Gb could be better !
Q1) Please have you updated your NVidia graphic card driver ? ... It's very important especially for 2015 versions !
... NVidia has released many NEW version of its drivers in May/June 2014 ...
Waiting ...
Patrice BRAUD
Message 16 of 34
Hi braudpat
I have updated all the thing need to be
Include the ACAD and window itself.
Even send the laptop back to IBM engineer to look into it.all they come bavk to me is it is normal.
How is it normal when it keep lagging and jammed.
Message 17 of 34
braudpat
Hello
Q1) Are you running with Hardware Graphic Acceleration ON ?
Q2) Which version for your NVidia Quadro K2100M driver ?
Patrice BRAUD
Message 18 of 34
jimoly
Maybe a little late, but if you are doing residential house plans,  Home Designer Pro is top of the line before you get into the Chief Architect series.  It does everything, mainly using "blocks" including furnishings.......and even 3D with rotated views.  I have both Autocad LT 13 and HDP and use HDP for house design.
Message 19 of 34
1629853
in reply to: JDMather
Hello JDMather,
I have no budget, I am currently using a MSI gaming laptop, it has 12G memory, i7-4700MQ, 1TB HD, GTX-770M video card. I am running window 8.1 and AutoCAD 14. This laptop is very heavy, especially I am taking it with me when I travel.
I am looking for a small power laptop, smaller screen, SSD HD, but with a powerful memory and video card. Can you give me some suggestions?
Albert,
Message 20 of 34
in reply to: jimoly
I need to buy a new desktop computer - I'm a student in an interior design program. I've been looking at the above computer with these details:
AMD A10-6700T
2TB
8GB
AMD Radeon HD 8650D Graphics
Can anyone tell me if this will suit my needs (I don't want to spend more than $1200)?
Or, suggest something better?
Thanks!
”Boost
