I'm looking for a CAD program that can handle importing dxf files for manipulation. I would also need to export cad file to Adobe illustrator or Adobe Photoshop (unless one of Autodesks programs allow for artistic manipulation such as adobe) and be able to be imported back into the CAD file if needed.
I ultimately need a 3-D CAD file object that has capability of having 2-D artistic effects made to it, to be able to export to a format for printing onto canvas material.
Does anyone know which (if any) AutoCad product can handle this?
Thanks! Lisa
Although this may not help you make a decision, just be aware that the dxf file format is a proprietary Autodesk file format.
Any other software besides an Autodesk product is doing their best to make that dxf file readable in any software, but it doesn't always pan out that way.
So not counting your requirements for artistic manipulation, any Autodesk product is the best for importing and exporting dxf files
In addition to the other comments...
"Painting" isn't something that is done to a 3D object. Your desired process of taking a 3D object, making artistic changes to it as a 2D image, then bringing it back into 3D for further manipulation isn't something that can be done. The process you are describing actually involves rendering the 3D objects with appropriate materials, lighting, textures, and so on to an image file (PNG, TIFF, etc.) and using image editor software to make changes to that image. You can't "unrender" an image back to a 3D object.
AutoCAD and AutoCAD-related vertical products can do basic rendering with limited settings. Navisworks Simulate can also do rendering from a wide variety of source formats but has limitations which aren't much better than AutoCAD. Dedicated visualization software such as 3DSMAX and Maya provide the highest level of production with an associated steep learning curve. There may be other products with similar processes, such as Inventor, Revit, or Fusion 360, which provide alternatives which bear exploring.
The .dxf file is coming from the software the developer of the product uses. I'm not able to disclose details, but I'm trying to artistically add a "skin" of sorts to the 3-D object - like say, a photo. Illustrator or photoshop would only be used to manipulate the photo. Is there a way to have prepared photo added to AutoCad 2014 and do a controlled wrap on only certain faces of the 3-d object? - Lisa
