hi all,
I am absolute beginner to Autocad, so please forgive me...
I used to add a length to a line by creating the line start point and hitting back space to enter the length. When I hit backspace now, it does not give me the option to enter the length.
Do you what setting I changed by accident?
Thanks!
Solved by steven-g. Go to Solution.
Welcome to the Autodesk forums.
I'm not sure I understand your process. If you only started the LINE command, then picked a start point, then <backspace> then typed a length, how did AutoCAD know which direction the line should go?
