AutoCAD 2013/2014/2015
New Member
0 Kudos
Post 1 of 4
Background Mask Attributes
1147 Views, 3 Replies
01-21-2013 08:31 AM
I am trying to create a block and include attributes that have the background masked.  I know how to mask the background in mtext but am curious if it is possible to do on attributes.
You can - you have to select "Multiple lines" in Attribute Definition window (ATTDEF command).
Than after you enter Tag and Prompt values, click on [...] box for Default. Next, specify location of attribute and select Background Mask from options icon at Text Formatting toolbar.
Thanks!! I will try that.
Distinguished Contributor
3 Kudos
Post 2 of 4
Re: Background Mask Attributes
01-21-2013 10:32 AM in reply to: VICTORRENO2309
New Member
0 Kudos
Post 3 of 4
01-22-2013 05:38 AM in reply to: VICTORRENO2309
Member
0 Kudos
Post 4 of 4
01-16-2015 05:41 PM in reply to: VICTORRENO2309
Can your create a background mask with using mapanntemplate or mapanntext?
