How do I stop autcad from deleting autosave files when it closes? We have network drives, multiple users and more often then we would like the wrong file will be replaced. If the autosave files exist in history we wont lose as much work.
Solved by Jroper. Go to Solution.
In some cases maybe you can use the .bak file to restore a previous version of the overwritten file?
But, the bigger question is why are co-workers overwriting a file with another file? We have the same situation as you said you have, alot of times with files from different projects named the same as files from other projects, and we almost never have files overwritten with the incorrect file.
Sounds like some co-workers need a slap upside the head 😉
How do I stop autcad from deleting autosave files when it closes?..... If the autosave files exist in history we wont lose as much work.
The only time you should ever need an autosave file would be if you have a power outage or something like that.
Normally.....
If you work on a drawing and then save it and close it, the last QSAVE you did will be newer than any autosave file that exists. = no need for the autosave file
If you work on a drawing and then quit without saving, then you do not want to save your changes. = no need for the autosave file
(That's why they are deleted)
But to directly answer your question, (not a recommendation, just a factual answer) -- you can configure your autosave directory so that you have write access, but not delete access.
I had a similar experience. But my issue was the autosave files were in monthly batches. after each month the folder was wiped clean. But this was the routine maintenance program by IT that was doing that.
still the only beef I have with AutoCAD's autosave, is the default location it places the file.
it's alway C:\Users\username\AppData\Local\Temp. The problem is that by default, the AppData folder is a HIDDEN FILE. If a user doesnt know this, the user would never find the autosave files. of course one can change this by changing where the systems points to save the file, by changing it in options.
A novice user should be going through the Recovery Manager to find/open autosave files. Unfortunately, It's not terribly reliable and may or may not show all available .sv$ and/or .BAK files in the autosave locations.
Even though AppData is hidden, you can easily type in %temp% in the address bar of Windows Explorer to take you to the users location you noted in your reply.
AutoCAD .sv$ file can be potentially be huge and fill up a hard drive fast. The \appdata\...\temp is a good candidate because it is a target of cleanup programs. Also, backup save files are best saved in a folder specific to a user's profile because they are most likely personal to what you are doing with your Window's profile. Say you were in a school lab where there were 5 different user profiles per computer. You wouldn't want to go digging for your save file among several other student's backup files in big common temp folder. The AppData area is hidden for most people's protection. Moving files in that area can potentially break your programs. It has to be personal and not breakable by you or another person. But for most people people who are the sole user on a computer, that the first thing they unhide.
"The only time you should ever need an autosave file would be if you have a power outage or something like that."
This is patently false. Being human, sometimes we close files we thought were saved and they're not. Wouldn't it be nice if there were a function that automatically saved our work periodically into a file that we could return to in case such an error in judgement occurred? What if that function was called AutoSave?
"Normally.....
If you work on a drawing and then save it and close it, the last QSAVE you did will be newer than any autosave file that exists. = no need for the autosave file" Abnormally, we do forget sometimes. See thoughts above.
"If you work on a drawing and then quit without saving, then you do not want to save your changes. = no need for the autosave file (That's why they are deleted)" Not necessarily so. See thoughts above.
"But to directly answer your question, (not a recommendation, just a factual answer) -- you can configure your autosave directory so that you have write access, but not delete access." That's nice that you finally answered the question or at least acknowledged that it is possible to have the AutoSave function operate on the basis for which many people here and elsewhere have expressed their need, so why on earth, after acknowledging that need, would you leave the discussion without explain how the modification is actually achieved? How the hell do we disable the auto delete function?
@hollandarc wrote:"The only time you should ever need an autosave file would be if you have a power outage or something like that."
"Normally.....
Why would you even think of using something that is normally automatically deleted as a backup?
Autosave is not a backup file. That's not what it was designed for. Don't try to use it in this fashion. It is only meant to be a way to minimize lost work in the case of an AutoCAD crash. That is it. If your workflow is so fragile that it requires something more reliable, I suggest talking to your IT people about storing past versions of files in a way that actually makes sense.
Just because you've been using the wrong tool for so long doesn't make it right and AutoCAD is a totally different beast from those other programs. If you want to continue using a screwdriver when you should be using a hammer, go right ahead but don't make demands that others teach you how to do it.
I have found that the best users don't use the tools in just one way.
I miss the ability to keep the autosave files when I close a file, they have there uses.
I hope the next version of autocad will allow that option.
Gerald
But when they do use them for something that they were not intended, they don't complain when it stops working.
Why don't you find a tool that is actually designed for that function?
Don't count on it.
