We are facing strange issue with all different versions of AutoCAD (2007, 2011, 2013). While users are working on the file, all of a sudden the contents (work done) are lost and it becomes all blank. The file size is same but when we open the file all the work done is not displayed, but just a blank screen.
It happens occasionally and there is some Automation Error in the command line below. The software is not hanging but the open file is in hang state and we have to close it. While closing whether we select yes/no the content (work done) is all lost. The temp location where the files are saved in one of the computer is become huge around 40GB will many Autocad autosave and temporary files; if it has anything to do with it !
Can anyone guide what could be the possible issue ?
Yes, that it happens on multiple drawings strongly suggests that it's additional software running on your machine and presumably whatever is doing that "indexing block ***". So to repeat, where is the command alias ET defined, and how?
If you uninstall whatever mechanism you are using for your cloud service - does the problem go away?
OK, so what ever is happening is going on at a lower level that your two-key LISP shortcuts - apparently it's intercepting command calls, and doing the indexing. As a suggestion - you may want to preface the comaand name you are calling with dot underscore,as in ._extend vs extend.
that (the indexing) is not normal. Once you track that down, you'll know what's causing the automation error. A rouge arx, a badly-designed dotNet , leftover VBA.
If you type in VBARUN, does anything show up in the Macros dialog??
Also try RKs suggestions to look for arx files that are loading....
@nedwards9820 wrote:
Does the record above indicate that AutoSave is calling the updating of
Indexes?
The updating of the indices is normal when INDEXCTL /= 0
But it should only happen during a SAVE, QSAVE, SAVEAS, or autosave.
Maybe try setting INDEXCTL to 0 to eliminate this from the problem here (this is a per-drawing sysvar)
We are still getting such Automation Error in all Draughtsman's computers despite of re-installing complete OS and Software.
; error: Automation Error. Drawing is busy.
Select objects: *Cancel*
If anyone got a solution or work-around for it, please reply !
try to update and download Autocad Service pack...
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9240618
Regards
The same problem is happening to me and I am losing all my work. That's really terrible.The problem that I dont know if this is a 3rd party virus or Autocad software error. It seems I will turn to work with Microstation soon if this problem persist as I see that Auto Cad is not concerned with such terrible problem.
>> I've bought a new computer and have not yet had the Automation Error on the new machine.
So it depends on the system as your problems are now gone ... it's a great step to know that.
And now: what are the differences between your old system and your new one? That might bring all users with such problems a step more to a solution!
Do you have 3rd party apps/tools/plugins/... installed? If so have you tried to run AutoCAD without that addon's? Have you tried to run AutoCAD with another AutoCAD profile or within another Windows user account?
BTW: what have you tried yet ... or was your message just for posting that you want to continue based on Microstation?
If you want help then let us know what you have tried, what software is running on your system, what hardware (especially graphic card) you have ... without any info we can't do anything.
Really? What answer have you got when you contacted the Autodesk support? (directly or via your AutoCAD dealer)?
- alfred -
Since the time we are facing this issue, we have tried below things,
- Re-installed AutoCAD but same issue.
- Created new profile but same issue with new profile as well.
- Installed latest version of AutoCAD with service packs, but not luck
- Format and installed Windows OS and AutoCAD again. No other software/tools or plug-ins installed/enabled, but no luck. (The PC is IBM brand i5 processor, 4GB memory, 1GB dedicated graphic card).
We have may branches with draughtsmans repectively in every branch office. Strange thing is that it is hapenning with all of them. Initiallly few branches were complaining, but some were fine. Now it is like spreading and all have the same issue !
>> In my experience, installing a new OS on a new hard drive and making a
>> fresh installation of AutoCAD does not solve this problem.
Previously you wrote that a new system does not have that issue. So if you had the problem on the old system including a fresh setup of the OS I guess you have used the same drivers and one of those might then be the source of the problem.
And especially as you had the problem and you have found a way to get around it YOU are the one who can show thee differences to possibly give the hint to solve the issues for others. Up to now you have not helped anyone else to get rid of it.
For me: I have not lost drawings for ages now (also none of the customers I support).
- alfred -
What OS and what graphiccard do you use (type and driver version)?
I hope it's not a 64bit Windows because then 4GB is the very lowest limit anyway.
- alfred -
