We are facing strange issue with all different versions of AutoCAD (2007, 2011, 2013). While users are working on the file, all of a sudden the contents (work done) are lost and it becomes all blank. The file size is same but when we open the file all the work done is not displayed, but just a blank screen.
It happens occasionally and there is some Automation Error in the command line below. The software is not hanging but the open file is in hang state and we have to close it. While closing whether we select yes/no the content (work done) is all lost. The temp location where the files are saved in one of the computer is become huge around 40GB will many Autocad autosave and temporary files; if it has anything to do with it !
Can anyone guide what could be the possible issue ?
This issue does not seem to be related to any Hardware or OS compatibility. Before facing this issue, it was all working fine with same Hardware and OS and the same version of AutoCAD software.
It is more likely to be a Virus / Worm / Trojan related to infecting .lsp or .fas files. Strange that the antivirus is not catching it.
All,
this is not an error that can be caused at will.
it seems the only time the error occurs is when you have been working intensely and for a long time in one or a number of files. I could post the drawing files, but unless you drew in them for six hours or so I doubt very much the error would occur.
Frankly, a vrius seems highly unlikley -- why would a virus-checker not find it? Why would it occur only after long periods of work?
My hope is that someone else with this error has a file/scenario that causes the error "reliably". I am certain that if I post my files you will not be able to replicate the error. I certainly can't.... until I've been working solidly for many hours.
it is only when you are deeply involved in a drawing that the resulting data loss becomes such a serious event.
-ne
Dear All,
We are facing the same issue. People in our engineering department are losing their work as the drawings are getting blanked. I have found out that there some files being created automatically in Desktop, Documents and working directory of the affected user named "acad.fas".
There is also a know virus named "Worm:ACAD/Kenilfe.A [F-Secure]|". I have checked the files and registry keys that this virus creates, i did'nt find any.
Please advise for a possible solution. I have also logged a case with Symantec for this problem. Once i get their feedback, i will update.
Thank YOu
Regards
Abdul Wajid
Hi Friends
In our company at least 4 computer were getting " Automation error " with data erased, To cure we formatted all affected computers and then onwards those computers not getting same error.
But today an anther computer got same error (first time) while finding cause I fond "Acad.fas" file was created in directory where cad files are located. After searching all computer I found “Acad.fas” file in My doc, Appdata, Program files and one more location and in all places file was created today only.
Internet searches leads to declare acad.fas as virus. If anyone aware of it please share it with us.
Note: After deleting acad.fas file user hasn’t work on same system hence I can’t conclude as deleted acad.fas as solution.
dear sir,
greeting of the day
i having problem with autocad2013 when i doing work in the model space sudden all done work erased all showing blank last one month i facing type this problem i humbly insist you pleawse guide me
thanks with regar
Saiyed 'kaif
Dear All,
I found the solution to the problem.
our more than 50 Engineers were facing this problem and we had to do following to fix the issue:
Problem solved.
Thank You
Regards
Abdul Wajid
I was afraid that some lisp routines are autoloading whenever autocad is started. I tried to create a new profile becasue autocad looks for lisp files and fas files in the user profile and installation directory.
In SP1 of they have added additional security modules, the AUTOLOADPATH and AUTOLOAD commands are not avaiable in the previous releases. Through this we can restrict to only look for lisp and fas files in the installation directory and to make changes and add files in that directory the user will have to put the administrative credentials.
For more information you can also consult below article by autodesk;
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20327810&linkID=9240617
Thank You
Regards
Abdul Wajid
Dear all
I have found very simple solution for the automation issue however it is required to have another PC without the same this error
i have tried that on my PC and it is working fine however make sure that the support folder which you copy it is from a PC with no old records for this issue
Regards
Faisal AG
I think it's a virus because when I change to "show hidden files" it's always creating acad.fas file.
I started having this problem last month after editting some files that originated in Iraq and contained some architectural blocks (which I removed). Now the error occurs in new drawings or older drawings created before. I have no add-ons or vba routines running. Just simple drawings with surfaces, feature lines etc. Now almost every drawing suffers this problem, usualy after 1 hour or more working, so it is getting very expensive. I'll try the fixes above but it seems the error comes in on a drawing and will probably spread to other users the same way.
Automation Error !
Same error happened in Auto CAD 2014. Even i already face this error in CAD 2013.
So still no one have find such a solution to correct this error.
the same is happening with me but im working on civil drg,I lost my three file,every thing is there except drg.here is my attached file.
