Hi everyone.
I am using AutoCAD 2015 (also have Civil 3D) @ my office.
For a survey i have to move points on the nearest Line/Pline.
For this work i have to select and move every single points and move them manually on the line.
It is becoming very daunting and time consuming.
I was wondering if there is any way to select points adjacent to a line and automatically move them on the line.
for lack of a better term, I have attached a GIF video showing the procedure i am using.
If there is away to do this automatically or more easily, please let me know.
Also let me know if I need any third party app for this, or other sofware.
Thanks all.
Solved by LyleHardin. Go to Solution.
This one seems to work fine:
I'm assuming you want to move them in such a manner so as not to affect the Z value of their coordinate.
You could set a new UCS, setting the X axis on the line you want the points to be on.
Then you select all the points to go on that line and in the properties manager set all their X values to 0. (Zero).
Still cumbersome, but it beats doing them one by one and you won't affect their elevation this way either.
thanks, it worked great. but i have to set the Y values to 0 to get the desired result
Ah, yes, the Y value... sorry about that!
Another thought came to mind. You want to be sure in World Coords that the Z values of the end of your lines are equal. In other words, when you set up your UCS along that line, you want to be sure the X axis is 'flat to the world'.
Glad it works for you. That looks like a tedious process!
Looks like River Soundings. Is it?
yes those are River Soundings.
could you please clarify more on your last thought.
I was thinking about the lines you are moving the points to. River Sections?
In World UCS, do the end points of those lines (sections) have the same Z value?
I was thinking if they did not, then setting your UCS with the X axis on that line might mess up the values when you move your points.
But, actually, now that I think about it, since you are just changing the Y value, it should not be a problem.
Sorry for the confusion.
You are aware of the River Analysis extension for Civil 3D right? It lets Civil 3D communicate with HEC-RAS if that's what you're doing.
Problem is, I don't think that extension is out for 2015 yet.
i am new in civil 3d. i dont know about that
my friend have auautocad civil 3d 2014 i could try on that.
This can be very easily solved with a little bit of programming. it's worth looking into the autocad api and you should be able to get most things done after a good 5-10 hours of study.
Moving the survey point changes the profile of the cross-section of the river bed. The river is only that deep AT that point, if you move it, the new location is a different depth. You don't really want to move the points, you want to define the river bed surface then determine what the cross-section profile should be along those straight lines. .....right??
