AutoCAD Forum
Automatic text edition
4 REPLIES 4
BSA_drafter1
296 Views, 4 Replies
I have around 2000 text to edit. Those are elevation from a survey. I need to add .380 to each of those 2000 elevations. Is there a way to put a formula somewhere to do that automaticaly?
4 REPLIES 4
Patchy
in reply to: BSA_drafter1
BSA_drafter1
in reply to: Patchy
I got the "formula" from your post but what am I suppose to do with it?
(defun c:addn ( / ss)
  (vl-load-com)
  (if (and (setq ss (ssget "X" (list (cons 0 "*text"))))
       (setq amt (getreal "\nPlease type the amount you would like to add: ")))
    (progn
      (mapcar '(lambda (z) (vla-put-textstring z (rtos (+ (atof (vla-get-textstring z)) amt) 2 3)))
          (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))))
  (princ)
Patchy
Use the one from Lee Mac, one way is copy and paste to the command line, then type in :  Text_Inc    and follow the prompt.
(defun c:Text_Inc (/ *error* ParseNumbers uFlag ss)
  (vl-load-com)
  ;; Lee Mac  ~  10.03.10
  (defun *error* (msg)
    (setvar 'NOMUTT 0)
    (and uFlag (vla-EndUndoMark *doc))
    (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")
        (princ (strcat "\n** Error: " msg " **")))
    (princ))
  (defun ParseNumbers (str / lst Num Aph x rtn)
    ;; Lee Mac  ~  20.09.09
    (setq lst (vl-string->list str) Num "" Aph "")
    (while (setq x (car lst))
      (setq lst (cdr lst))
      (cond (  (and (/= "" Num) (= 46 x))
               (setq Num (strcat Num (chr x))))
            (  (< 47 x 58)
                     rtn (cons Aph rtn) Aph ""))
            (t (setq Aph (strcat Aph (chr x))
                     rtn (cons (read Num) rtn) Num ""))))
    (vl-remove nil
      (vl-remove "" (reverse (cons Aph (cons (read Num) rtn))))))
  (setq *inc* (cond (*inc*) (1.0)))
  (setq *inc* (cond ((getreal (strcat "\nSpecify Increment <"
                                      (vl-princ-to-string *inc*) "> : ")))
                    (*inc*)))
  (setq *doc (cond (*doc) ((vla-get-ActiveDocument (vlax-get-acad-object)))))
  (setvar 'NOMUTT 1)
  (princ "\nSelect Text to Increment <All> : ")
  (if (or (ssget "_:L" '((0 . "MTEXT,TEXT")))
          (ssget "_X"  '((0 . "MTEXT,TEXT"))))
    (progn
      (setq uFlag (not (vla-StartUndoMark *doc)))
      (vlax-for obj (setq ss (vla-get-ActiveSelectionSet *doc))
        (vla-put-TextString obj
          (apply (function strcat)
                 (mapcar
                   (function
                     (lambda (x) (if (vl-position (type x) '(INT REAL))
                                   (vl-princ-to-string (+ x *inc*)) x)))
                   (ParseNumbers (vla-get-TextString obj))))))
      (vla-delete ss)
      (setq uFlag (vla-EndUndoMark *doc))))
  (setvar 'NOMUTT 0)
  (princ))
3wood
You can also try attached ALTEXT.vlx, settings as below:
”Boost
