I have around 2000 text to edit. Those are elevation from a survey. I need to add .380 to each of those 2000 elevations. Is there a way to put a formula somewhere to do that automaticaly?
Solved by Patchy. Go to Solution.
I got the "formula" from your post but what am I suppose to do with it?
(defun c:addn ( / ss)
(vl-load-com)
(if (and (setq ss (ssget "X" (list (cons 0 "*text"))))
(setq amt (getreal "\nPlease type the amount you would like to add: ")))
(progn
(mapcar '(lambda (z) (vla-put-textstring z (rtos (+ (atof (vla-get-textstring z)) amt) 2 3)))
(mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))))
(princ)
Use the one from Lee Mac, one way is copy and paste to the command line, then type in : Text_Inc and follow the prompt.
(defun c:Text_Inc (/ *error* ParseNumbers uFlag ss) (vl-load-com) ;; Lee Mac ~ 10.03.10 (defun *error* (msg) (setvar 'NOMUTT 0) (and uFlag (vla-EndUndoMark *doc)) (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\n** Error: " msg " **"))) (princ)) (defun ParseNumbers (str / lst Num Aph x rtn) ;; Lee Mac ~ 20.09.09 (setq lst (vl-string->list str) Num "" Aph "") (while (setq x (car lst)) (setq lst (cdr lst)) (cond ( (and (/= "" Num) (= 46 x)) (setq Num (strcat Num (chr x)))) ( (< 47 x 58) (setq Num (strcat Num (chr x)) rtn (cons Aph rtn) Aph "")) (t (setq Aph (strcat Aph (chr x)) rtn (cons (read Num) rtn) Num "")))) (vl-remove nil (vl-remove "" (reverse (cons Aph (cons (read Num) rtn)))))) (setq *inc* (cond (*inc*) (1.0))) (setq *inc* (cond ((getreal (strcat "\nSpecify Increment <" (vl-princ-to-string *inc*) "> : "))) (*inc*))) (setq *doc (cond (*doc) ((vla-get-ActiveDocument (vlax-get-acad-object))))) (setvar 'NOMUTT 1) (princ "\nSelect Text to Increment <All> : ") (if (or (ssget "_:L" '((0 . "MTEXT,TEXT"))) (ssget "_X" '((0 . "MTEXT,TEXT")))) (progn (setq uFlag (not (vla-StartUndoMark *doc))) (vlax-for obj (setq ss (vla-get-ActiveSelectionSet *doc)) (vla-put-TextString obj (apply (function strcat) (mapcar (function (lambda (x) (if (vl-position (type x) '(INT REAL)) (vl-princ-to-string (+ x *inc*)) x))) (ParseNumbers (vla-get-TextString obj)))))) (vla-delete ss) (setq uFlag (vla-EndUndoMark *doc)))) (setvar 'NOMUTT 0) (princ))
