Hi I am having one query. I always recieves dwg file of diff. units from my clients. I have to convert those drawing dim manually. Is there any way by which i can import those diff units dwg files in my dwg file and get the content of these files automatically converted to the units that i want. Help is most appreciated. I spend lot of time converting units.
Best Regards.
Mohan Suryawanshi
Solved by maxim_k. Go to Solution.
Hi Mohan,
The only one thing you have to do is to check the value INSUNITS in your drawing and the drawings you are inserting in yours.
For example if your drawing is in metric units (A) - set INSUNITS=4 in it, then if the drawing you want to insert (B) is Imperial - set INSUNITS=1 in it.
Now when you will insert (as block with INSERT command) drawing B into drawing A - AutoCAD will add scaling automatically.
Maxim
Hi Maxim Thanks for your prompt reply,
Still i did not understood the functioning of the values you gave. Did these values are conversion factors. I can understand 1inch-25.4mm. Please elaborate it will help me a lot
Thanks & Regards
Mohan S.
