I have this code:
(defun openTemplatesinDC ()
(progn
(command "adcnavigate" "C:/Templates/Templates.dwt")(princ)
Is there any way to have it go one step further and open the "Layouts" sub-section?
Solved by hmsilva. Go to Solution.
Try adding this line before the last (princ) and let me know if it works for you:
(setvar "ctab" "layout1")
Warm regards from Los Angeles,
Emmanuel
@smiddleton wrote:
I have this code:
(progn
Hi smiddleton,
try
(defun openTemplatesinDC () (command "adcnavigate" "C:/Templates/Templates.dwt/Layouts") (princ) )
Hope that helps
Henrique
That worked PERFECT! Seems way to logical now that I've been shown!
Thanks to all!
