I'm planning to buy Msi laptop 2.5 GHz, i7 4710 MQ, 32 GB Ram, GTX 880- 8 GB graphic card
To use it for AutoCAD, Revit and 3D max."Heavy work"
But when I read more about the graphic card "GTX 880", some users said that it does not work well with these softwares, because it is mainly for gaming not modeling and rendering.
The thing is Quadro series of graphics card are not available at all in my country.
The GTX 880 it the highest card available here.
Please tell me what to do, go for this msi? Or buy a MacPro retina 15”?
Thank you.
Solved by braudpat. Go to Solution.
There might be some information of interest to you in this
Hello from France
Welcome to the Autodesk/AutoCAD Forums !
Generally NVidia GTX (High End ones) are performing very well with ACAD, Revit, Inventor ...
It's the "DirectX" problem !
And NVidia Quadro are slower and more expensive !!
Today the fastest graphic card (for ACAD, etc) is the NVidia GTX 780 TI ...
But if you plan to run ALSO SolidWorks, Catia, etc, you need a NVidia Quadro 2000/3000/4000/etc ...
It is the "Open GL" problem !
Patrice BRAUD
@braudpat wrote:
But if you plan to run ALSO SolidWorks, ... !
I run SolidWorks fine (not interested in the Real View Graphics) on my Alienware.
JDMather
Thank you for replaying, but I think the link you suggested to me have an old information
becouse there are newer things than this nowadays.
or maybe I did not get what you want me to read .
Which graphic card you have in your alineware ?
Thank You.
Hello JD
YES for SW, if you are not interested with Real View, a fast GTX 780 / GTX 780 TI is the best ! - idem for ACAD, etc ...
Patrice BRAUD
Hello Alio
You said >>>
What do you mean by "It's the "DirectX" problem !" ? I did not get it,
And I'm working only with autocad, revit and 3d max.
So shall I go fot the GTX 880 Mx ?
--> Sorry for my word "problem", it was french humour !
There is NO problem with DirectX & ACAD, etc ...
I said this because ACAD, etc, is using DirectX and not OpenGL so a fast NVidia GTX is the best choice !
In France, I know people with older version of Alienware17" (GTX 780M Series, if I rememeber well) and they are HAPPY with their hardware !
So the NEW GTX 880M (8 Gb) will be OK !!!
Patrice BRAUD
