Hi everybody
Excuse my english, I'm french.
I just installed AutoCad 2014 student. When I launch the software, an error message appears and says: "the exception C0000005 at 7337F5BFh address has not been processed"
I click ESC twice and the message disappears, then when I click anywhere in the software or even that I want to create a new project, AutoCad freez
Help, please.
Configuration of my laptop :
Toshiba satellite
Intel core i3 CPU
M380 @ 2.53 GHz, 2.53 GHz
RAM 4.00 Go
Windows x64 bits
Thank you!
It might be worth starting over with the install:
Autodesk Recommended Clean Install Procedure:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240817&id=2887771&siteID=123112
Then make sure that you download and install the 64 bit Student Version.
What version is the OS?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Hi, thank for your help. I will try this and I will let you know the result.
I'm on Windows 7, 64 bits and yes, it's 64 bits version that I used. When I try to installe the 32 bits version it's not working, the installe nitifies me to use a 64 bits.
Thank you!
