Every time i start up AutoCAD 2015 or print/publish i get a error message. I have traced the link and its a shortcut link, the prjoect managers say i still need this file so i cant delete it. It just makes me hit okay every time so everything prints just fine. Is there any way to have autocad just accept it without the window poping up or is their a way to get rid of it all together? I have also attached a image file of the warning.
Solved by john.mckenzie. Go to Solution.
This is an oldie but a goodie.
copy
"addplwiz.exe" from wherever it exists and put it in the same directory as your ctb files or add a path to it under options. I usually copy it over so that all is well especially if everyone points to the same place.
cheers
