AutoCAD 2013/2014/2015
Member
incompetencilla
Message 1 of 7 (1,221 Views)
AutoCAD to Rhino (and general surface problems)
1221 Views, 6 Replies
01-17-2013 10:10 PM
First off, please forgive me, I am completely new to AutoCAD as a student who has only recently downloaded the trial version and has no other experience with CAD programs. I, however, aim to learn.
Anyhow, my current problem is rather simple yet the solution eludes me. I have a planar surface in AutoCAD made from a curve imported from Excel and straight lines. However, for the project that I have, I need to ship the file over to a peer who uses Rhino. Whenever my friend opens the file in any of the formats I've tried (every year of dxf as well as dwg) all he sees in Rhino is straight lines, regardless of the perspective. I downloaded the evaluation copy of Rhino to experiment and found the same result, which I'm guessing is also how blank files are displayed.
Does anybody have any suggestions for this?
Your main drawing is so tiny and on the right of it there are 2 gigantic lines.
After erase the lines I opened it with rhino and autocad without a problem.
Member
incompetencilla
Message 2 of 7 (1,198 Views)
Re: AutoCAD to Rhino (and general surface problems)
01-18-2013 03:23 PM in reply to: incompetencilla
Anyone help please?
Patchy
Message 3 of 7 (1,193 Views)
01-18-2013 04:18 PM in reply to: incompetencilla
Attach your drawing here. Let's see.
stevev0983
Message 4 of 7 (1,190 Views)
01-18-2013 04:48 PM in reply to: incompetencilla
You should post the drawing that you have and I'll try to open it in Rhino and see what I get. Simply put the drawing up and I'll take a shot at it.
Member
incompetencilla
Message 5 of 7 (1,187 Views)
01-18-2013 04:57 PM in reply to: incompetencilla
Here's the file.
Patchy
Message 6 of 7 (1,161 Views)
01-18-2013 08:51 PM in reply to: incompetencilla
Member
incompetencilla
Message 7 of 7 (1,153 Views)
01-19-2013 12:17 AM in reply to: Patchy
I can't believe such a simple problem and solution escaped me. Thanks a ton!
