AutoCAD 2013/2014/2015
Distinguished Contributor
1 Kudo
Post 1 of 12
AutoCAD slow
368 Views, 11 Replies
01-30-2013 05:37 AM
When I am in AutoCAD almost every command I do may computer has to sit there and think for 20-30 seconds before it actually executes the command.  Would this have anything to do with our company server?  There are other coworkers that would have the same problem too but not as often as I would have the issue.  I think our server is running 2003.
*Expert Elite*
1,589 Kudos
Post 2 of 12
Re: AutoCAD slow
01-30-2013 05:44 AM in reply to: jamied2000
What are the PCs specs that you are running AutoCAD on? adn Windows version?
WinServer2003 is not a supported OS to run the application and it's the worst OS to try and do work in with AutoCAD as it tries to manage your office's server/network/ email needs, if that is what you meant by your light post above.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
1 Kudo
Post 3 of 12
Re: AutoCAD slow
01-30-2013 05:57 AM in reply to: pendean
Eash AutoCAD is on their own computer.  It is not on the server.  I have attached my pc specs.
*Expert Elite*
1,589 Kudos
Post 4 of 12
Re: AutoCAD slow
01-30-2013 06:07 AM in reply to: jamied2000
Good systems: are the problems in certain files only, or in all files?
What if you start a new file, commands are just as slow?
1 Kudo
Post 5 of 12
Re: AutoCAD slow
01-30-2013 06:11 AM in reply to: pendean
It is pretty much every file.  Not sure on a new file.  Currently it is not doing it to mine but another coworkers started doing it.
*Expert Elite*
1,589 Kudos
Post 6 of 12
Re: AutoCAD slow
01-30-2013 06:12 AM in reply to: jamied2000
"...started doing it..."
So it's not constant and all the time, this is a recent observation (or sporadic)?
1 Kudo
Post 7 of 12
Re: AutoCAD slow
01-30-2013 06:14 AM in reply to: pendean
Well it has been pretty constant for quite a while now.
*Expert Elite*
259 Kudos
Post 8 of 12
Re: AutoCAD slow
01-31-2013 01:34 AM in reply to: jamied2000
Hello
Have you some strange "ACAD.lsp" files created everywhere with your DWGs files ?
Bye, Patrice
Bye, Pat ( Supporting Troops )
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Compliment) - Thanks
*Expert Elite*
473 Kudos
Post 9 of 12
Re: AutoCAD slow
01-31-2013 04:23 AM in reply to: jamied2000
You might give this a shot. The article is old and "Filemon" has been replaced by "ProcessMonitor", but the idea is the same. Let this tool monitor all file/registry activity while your AutoCAD is "sitting and thinking 20-30 seconds". There will have to be a clue in there as to what is going on.
*Expert Elite*
501 Kudos
Post 10 of 12
Re: AutoCAD slow
01-31-2013 08:00 AM in reply to: rkmcswain
Also check your annotation scales, if you are not controlling them they tend to accumulate.
Any third-pary applications and/or vertical products in use?  Referenced images?
If you are going to fly by the seat of your pants, expect friction burns.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Post to the Community
New Post
