AutoCAD Forum
AutoCAD simplifies/extrapolates/segmentates object/curves when coping them
6 REPLIES 6
jacob
598 Views, 6 Replies
Hy,
this is making me crazy. I am designing a microfluidic chip structure in simple 2D, however there are quite some array of copies.
Now when I copy sets of objects the quality of the objects are losening quality. Like you see on the picture I zoomed in and you see the curved parts getting segmented more and more. When I store it that way it seems to stay that way. Not completely sure if that is a viewing problem or a decomplexification of the real CAD data ... which would be HORRIBLE if AutoCAD does that without a notification.
How can I prevent that behaviour? I wanna have my structures stay the way a drew it!
6 REPLIES 6
jacob
in reply to: jacob
To mention that drawing is submillimeter scale ... 0.002mm ist the smallest distance.
M_Hensley
in reply to: jacob
Usually this is just a display issue, and if you REGEN it goes away. You can also try setting VIEWRES to 20000 and WHIPARC to 1 and see if that helps any.
dgorsman
in reply to: M_Hensley
A little more elaboration: because working with curves is computationally expensive, AutoCAD "cheats" when displaying them and uses straight segments instead.  The variables mentioned control how much cheating is done - less cheating requires more processing.  Note that this is *only* in the display, not the actual data.
Not sure if you are drawing with all those decimals or not... a unit is a unit, and the user can select what it means in order to make a good drawing.  For example if everything is on the micron scale one unit could be one micron to save a lot of zero-point-zerozerozerozeroblahblah data entry and display.  If this needs to exist in something that is in a larger scale (e.g. millimeters), then the larger object can be done with one unit as one millimeter, and the circuitry referenced in and scaled appropriately.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
jacob
in reply to: dgorsman
Thank you guys, that did. the job!
After changing those setting things where displayed correctly and I know it's not a native data error, which makes me relax. 😉
Also thank you for the deeper explanation.
Are those settings program or file specific?
sthompson1021
in reply to: jacob
VIEWRES is saved in the dwg, WHIPARC is a system setting.
jacob
in reply to: sthompson1021
THX!
”Boost
