AutoCAD Forum
Autocad profile export/import
2 REPLIES 2
695 Views, 2 Replies
Good morning.
I've rolled out a new computer with Autocad 2013. Part of this rollout was exporting the user profile from Autocad 2011 and an attempted import into Autocad 2013. However, when using the import utility, Autocad 2014 freezes and locks up. Is there something that can be done to successfully import an Autocad 2011 profile into Autocad 2014?
Eddie
2 REPLIES 2
dgorsman
Enough has changed between the versions that its usually better to rebuild your profiles and workspaces.  If you have custom UI content, its best stored in separate CUIx files so it can be partially loaded to a new version.
in reply to: dgorsman
Thanks dgorsman for the quick response!! Have a great day.
”Boost
