Hi.
When I right-click over the OSNAP icon, I can't access the running OSNAP settings. SHIFT/R-click Snap overrides are OK.
Tried typing DESTTINGS. It's almost as if the dilogue box appears offscreen.
Any ideas?
Solved by FHull. Go to Solution.
Solved by kadmonkee8. Go to Solution.
try this
ALT + SPACEBAR, then M, then arrow keys left or right. If it is truly off screen, it will come floating back
Thanks. I knew there was a shortcut for this, but I couldn't remember it.
Worked a treat.
