AutoCAD Forum
AutoCAD/M 2015 IGES options
4 REPLIES 4
M.Dyer95
548 Views, 4 Replies
I recently installed AutoCAD 2015 Mechanical on a new machine. When I use the IGESOUT command the proper translation window pops up as shown in picture #1. The dialog box does not show the options button where I can manipulate what layers are exported via IGES. I have attached a second attachment from AutoCAD mechanical 2014 showing the options button in the IGES translation window that I have previously used with success.
4 REPLIES 4
M.Dyer95
in reply to: M.Dyer95
Forgot to mention that CMDDIA value is 1 as well.
M.Dyer95
So in essence how would I be able to recover the options button in the IGES translation window in AutoCAD Mechanical 2015?
pendean
Isn't the command IGESEXPORT (or EXPORT) in 2015? It is in plain AutoCAD 2015 where you are posting and the pop-up here looks like your screenshot (plain AutoCAD).
Are you running MECH2015 "as AutoCAD" by chance?
MECH forum is here if you need it http://forums.autodesk.com/t5/autocad-mechanical/ct-p/2002 .
M.Dyer95
in reply to: pendean
It is AutoCAD Mechanical 2015 so I'll post in the Mechanical Forum. IGESEXPORT leads to IGESOUT in Mechanical.
”Boost
