For some reason I can no longer access the shortcut menu in command / edit mode using right click - right click just acts as Enter. None of the options have been changed. Any suggestions on how to get the shortcut menu back?
Solved by nestly2. Go to Solution.
Check Shortcut menus and Right-Click settings, and also verify that Noun/verb selection is enabled (PICKFIRST = 1)
I just loaded 2015 MEP here. Shortcut menus do not work as noted below in the LT version.
