if i have a one autocad 2015 with single site and single activation code but when i activate it in two system then both shows activeted why this happend...?????
Solved by JDMather. Go to Solution.
You can activate your license twice - but only run one machine at a time.
If you did not intend to burn one of your two activations - you should have used the license transfer utility.
The CADWhisperer YouTube Channel
